Broadband RAS over PPPoe
vikas kumar
Dear AllI am configuring Broadband RAS over PPPoe on Cisco 7206 ( IOS  12.2(33) SRD).
some  commands i am not able to run like
aaa  authorization subscriber-service default group AAA-SERVERS
aaa server radius sesm
scenario is  like this
END  User-> Broadband RAS->(Management software with DHCP server)->  Bandwidth manager-> core Router -> Internet
Broadband  RAS will manage All internet user with the help of management software.
please help  me
vikas
9 Replies 9
Giuseppe Larosa
Hello Vikas,
have you enabled aaa new-model with
conf t
aaa new-model
this is required in order to run other aaa commands
in you have already aaa new-model
post
sh ver | inc image
it may be a question of feature set
Hope to help
Giuseppe
Hi Giuslar
thanks so much for reply.
i have enable AAA new model.
i configured other aaa commands
BRAS#show version | inc image
System image file is "disk2:c7200p-ipbase-mz.124-15.T9.bin"
regards
vikas
Hello Vikas,
ipbase means basic features you likely need another feature set.
the feature navigator can help you to choice the right image once the name of the feature is known
http://www.cisco.com/go/fn
Edit:
I will come back when I will have an idea about the feature you need
Edit2:
I couldn't find any reference to the two commands you have mentioned in several command references of 12.4T IOS
may you provide a link of where you have found these commands?
You may be attempting to use commands that were supported in an older IOS image and that have been replaced by other ones
As noted by Chetan you need a more powerful feature set for sure.
Hope to help
Giuseppe
HI GUISLAR
thanks for your support and suggestion ,
i have to configure Cisco 7206 As BRAS for an ISP, i got these Commons from
http://www.cisco.com/en/US/docs/ios/solutions_docs/edge_ios/dep_ge.pdf
can you please help me to do this.
if i will get concept that will be great to do this job, because few things are very confusing.
thanks with regards
vikas kumar
The Output that you post System image file is "disk2:c7200p-ipbase-mz.124-15.T9.bin" not support this feature.
The Below IOS Support the AAA Authorization and Authentication Cache , AAA server group  & These are IPBase W/O Crypto
15.0(1)M2c7200-ipbase-mz.150-1.M2.bin51264
15.0(1)M1c7200-ipbase-mz.150-1.M1.bin51264
15.0(1)Mc7200-ipbase-mz.150-1.M.bin51264
12.2(33)SRE1c7200-ipbase-mz.122-33.SRE1.bin51264
12.2(33)SREc7200-ipbase-mz.122-33.SRE.bin51264
12.2(33)SRD4c7200-ipbase-mz.122-33.SRD4.bin12864
12.2(33)SRD3c7200-ipbase-mz.122-33.SRD3.bin12864
12.2(33)SRD2ac7200-ipbase-mz.122-33.SRD2a.bin12864
12.2(33)SRD2c7200-ipbase-mz.122-33.SRD2.bin12864
12.2(33)SRD1c7200-ipbase-mz.122-33.SRD1.bin12864
12.2(33)SRDc7200-ipbase-mz.122-33.SRD.bin12864
12.2(33)SRC6c7200-ipbase-mz.122-33.SRC6.bin12864
12.2(33)SRC5c7200-ipbase-mz.122-33.SRC5.bin12864
12.2(33)SRC4c7200-ipbase-mz.122-33.SRC4.bin12864
12.2(33)SRC3c7200-ipbase-mz.122-33.SRC3.bin12864
12.2(33)SRC2c7200-ipbase-mz.122-33.SRC2.bin12864
12.2(33)SRC1c7200-ipbase-mz.122-33.SRC1.bin12864
12.2(33)SRCc7200-ipbase-mz.122-33.SRC.bin12864
Chetan Kumar
Dear Chetan
please tell me what should i do change the IOS or what else.
i have to configure Cisco 7206 as BRAS for an ISP.
i dont have any idea to do this..
please help me,
thanks with regards
vikas kumar
Hi  Vikas
Frist of all you need to download an IOS from Cisco . ( It Requried CCO Login )
Then Using TFTP you can change the IOS , But I Suggest you to go with any Advance Security Image not ip base image.
You can use the cisco navigator to find the best IOS & Respective feature  : http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
You can refer the below link for installing an IOS .
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/prod_release_note09186a00800810f3.html#35260
Chetan Kumar
Hi chetan
thanks for your support and suggetions.
i got image in disk2:  c7200p-ipbase-mz.122-33.SRD.bin.
i ran BOOT SYSTEM to boot from this file
now i am able to run this AAA Commands. but few thing i want to configure
1. AAA Shared Secret Configured In NAS(Cisco BRAS)
2.Dynamic Port (For CoA and PoD)
3. Dynamic Secret (if it is different than main Shared Secret)
4.Pre-paid service(s) details (Configured in Cisco BRAS).
can you please explane this in details and how to do this.
thanks with regards
vikas kumar
Hi Vikas
I am not so used to with BRAS configuration , Please check the below link , May be that can help you.
http://www.cisco.com/en/US/docs/ios/solutions_docs/edge_ios/dep_ge.html
Chetan Kumar
