Catalyst 3750 for BGP peering over MPLS
gsidhu
Level 3
Level 3
I am thinking of using Catalyst 3750 switches (running IP Services image) for peering with Service Provider PE routers.
Are there any disadvantages /limitations in using Catalyst 3750 switches for this purpose over Cisco router platform?
shivlu jain
Level 5
Level 5
hi
you can use the switch but it cannot perform like router.
regards
shivlu jain
Hello Gurmakh,
the C3750 is fine if you are going to receive a moderate amount of BGP routes up to few thousands (enteprise use)
the C3750 will not be able to perform some routers functions like NAT.
besides this it should be fine for acting as CE router for an enteprise site
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for the confirmation.
Gurmakh
