Choosing between ISIS and OSPF
prakashcsco
Dear folks,
what are the choosing criteria between ISIS and OSPF in carrier networks.
what are pros and cons of ISIS when compared to OSPF
and Finally i am trying to study ISIS which Material do u Prefer...
Thanks in Advance
Hello.
ISIS is simpler than OSPF (less options and less points of failure) in terms of design and support.
Vinit Jain
Other benefit with ISIS is a lot a new enhancements can be made easily by creating a new TLV and integrating it. For ISIS, there are couple of good Cisco Press books:
IP Routing on Cisco IOS, IOS XE, and IOS XR: An Essential Guide to Understanding and Implementing IP Routing Protocols
http://www.ciscopress.com/articles/article.asp?p=26850
Hope this helps.
Vinit
--Vinit
