Configuring LS1010
Hi All,
        May i ask anyone to please help with configuring an LS1010 switch with  some ATM cards?.
The switch has the following:
LS1010#sh hardware
LS1010 named LS1010, Date: 00:59:51 UTC Sun Oct 31 2010
Feature Card's FPGA Download Version: 10
Slot Ctrlr-Type      Part No.  Rev  Ser No  Mfg Date   RMA No. Hw Vrs  Tst EEP
1/0 155MM PAM       73-1496-04 A0 16096050 Nov 17 99 00-00-00   4.0     0   2
1/1 155MM PAM       73-1496-03 A2 09014929 Apr 26 98 00-00-00   3.1     0   2
2/0 ATM Swi/Proc    73-1402-04 E0 05404201 Mar 05 97 00-00-00   3.2     0   2
2/1 FeatureCard1    73-1405-03 B0 03670645 Mar 05 97 00-00-00   3.2     0   2
DS1201 Backplane EEPROM:
Model    Ver. Serial   MAC-Address  MAC-Size RMA RMA-Number MFG-Date
LS1010      2 68018910 0030943D7D00      256   0          0 Nov 03 1999
Hence are connected to two 3640 routers:
Router-2(config)#do siib | in ATM
ATM1/0                     unassigned      YES NVRAM  administratively down down
Will be grateful if could be led on how to make the two routers communicates via the switch?.
Thanking you all in advance,
Olu
tonio.ojea
You have to configure IP over PVC in both routers
R1
interface ATM1/0.1 multipoint
description R1_2
ip address 1.1.1.1 255.255.255.252
pvc 1/66
  protocol ip 1.1.1.2
  encapsulation aal5snap
R2
description R2_1
ip address 1.1.1.2 255.255.255.252
pvc 1/66
  protocol ip 1.1.1.1
Now create a VC in the LS1010 for the ports where the routers are connected.
interface ATM1/1/0
no ip address
atm pvc 1 66  interface  ATM1/0/0 1 66
