CSPF algorithm is running by MPLS-TE or the extended ISIS/OSPF ?
superkliko
Title says all, some resources mention MPLS-TE and some others ISIS/OSPF.
Nagendra Kumar Nainar
CSPF is an algorithm that uses the database populated by OSPF/ISIS to calculate a path using the constraints provided as input, convert the path to ERO and provide it to MPLS-TE which can use it to establish the LSP.
So OSPF/ISIS here can be considered as protocol that helps build the TE database, MPLS-TE can be considered as consumer and CSPF as a process that uses TE database and gives what MPLS-TE wants ;)
-Nagendra
Thank you Nagendra,
The extended ISIS/OSPF are creating 2 DBs one for unicast LSDB and one for the TE-LSDB, then CSPF is using the TE-LSDB and TE-Constraints (user defined) to build the ERO, all good so far.
Still though not sure if CSPF running under the ISIS/OSPF or MPLS-TE process, I presume under the IGPs.
