Selective export/import between VRFs using route-maps
tim
Community Member
Does anyone know where I could find detailed information on configuring export/import route-maps for exchanging via routing information between VRFs.
I have 3 VRFs. VRF1 and VRF2 are exchanching with VRF3, but not between each other. Both VRF#1 and VRF#2 have default route in their RIBs. I need to receive into VRF#3 default route from VRF#1, but not from VRF#2.
Timothy
8 Replies 8
1- You can use an export map on VRF#1 to add a route-target on the default route that matches the route-target imported by VRF#3.
2- You can use an export map on VRF#2 to remove the route-target that matches the route-target imported by VRF#3
Here's an example:
ip vrf VRF#1
rd 192.168.4.1:1
export map export_default
route-target export 192.168.4.1:1
route-target import 192.168.4.1:1
ip prefix-list default seq 5 permit 0.0.0.0/0
route-map export_default permit 10
match ip address prefix-list default
set extcommunity rt 192.168.2.1:1 additive
rt 192.168.2.1:1 is the route-target imported by VRF#3 in this case.
Hope this helps,
Unfortunately it doesn't work. Probably I've missed something, when described my topology...Note, that all three VRF are on the same (7301) router. VRF#1 and VRF#2 have full-views (via eBGP) from different upstreams. What I need to get into VRF#3, is mixed (VRF#1/VRF#2) full-view with default route from VRF#1.
So, I've configured following:
ip vrf VRF#1
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf VRF#2
rd 1:2
export map export-vrf2
route-target export 1:2
route-target import 1:2
ip vrf VRF#3
rd 1:3
import map import-vrf3
route-target export 1:3
route-target import 1:3
ip extcommunity-list 1 permit rt 0.0.0.0:2
ip prefix-list default seg 5 permit 0.0.0.0/0
route-map export-vrf2 permit 10
match ip addess prefix-list default
set extcommunity rt 0.0.0.0:2 additive
route-map import-vrf3 deny 10
match extcommunity 1
It looks like "set extcommunity" string in route-map export-vrf2 doesn't work, because i have following output when performing command:
#show ip bgp vnpv4 vrf VRF#3 0.0.0.0/0
BGP routing table entry for 1:3:0.0.0.0/0, version 27073
Paths: (2 available, best #2, table VRF#3)
Not advertised to any peer
Local, imported path from 1:1:0.0.0.0/0
X.X.X.X from X.X.X.X (X.X.X.X)
Origin IGP, metric 0, localpref 100, valid, internal, best
Community: blah blah blah
Extended Community: RT:1:1
Local, imported path from 1:2:0.0.0.0/0
Y.Y.Y.Y from Y.Y.Y.Y (Y.Y.Y.Y)
Extended Community: RT:1:2
As we can see excommunity 0.0.0.0:2 hasn't been added, so the prefix hasn't been filtered...
Tim.
You shouldn't set the "route-target export 1:3" for VRF#1 and VRF#2 and use the "export map" to attach the appropriate route-target instead. By using the "route-target export" all prefixes will be tagged and will be accepted by the "route import 1:3" configured on VRF#3.
Here's a quick test that I ran:
ip vrf VRF#1
rd 1:1
export map export-vrf1
ip vrf VRF#2
rd 1:2
ip vrf VRF#3
rd 1:3
route-map export-vrf2 permit 20
set extcommunity rt 1:3 additive
route-map export-vrf1 permit 10
Here's the result:
R1#sh ip ro vrf VRF#1
C 192.168.1.0/24 is directly connected, Ethernet0/0
S* 0.0.0.0/0 [1/0] via 192.168.1.2
R1#sh ip ro vrf VRF#2
C 192.168.2.0/24 is directly connected, Ethernet1/0
S* 0.0.0.0/0 [1/0] via 192.168.2.2
R1#sh ip ro vrf VRF#3
B 192.168.1.0/24 is directly connected, 00:21:50, Ethernet0/0
B 192.168.2.0/24 is directly connected, 00:21:50, Ethernet1/0
C 192.168.3.0/24 is directly connected, Ethernet2/0
B* 0.0.0.0/0 [20/0] via 192.168.1.2 (VRF#1), 00:21:50
R1#
R1#sh ip bgp v vrf VRF#3 192.168.1.0
BGP routing table entry for 1:3:192.168.1.0/24, version 10
Paths: (1 available, best #1, table VRF#3)
Local, imported path from 1:1:192.168.1.0/24
0.0.0.0 from 0.0.0.0 (1.1.1.1)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, external, best
Extended Community: RT:1:1 RT:1:3
R1#sh ip bgp v vrf VRF#3 192.168.2.0
BGP routing table entry for 1:3:192.168.2.0/24, version 13
Local, imported path from 1:2:192.168.2.0/24
Extended Community: RT:1:2 RT:1:3
R1#sh ip bgp v vrf VRF#3 0.0.0.0
BGP routing table entry for 1:3:0.0.0.0/0, version 8
192.168.1.2 from 0.0.0.0 (1.1.1.1)
R1#
Hope this helps,
Hi!
now it works 🙂
thank you for support, I just thought that import/export map overrides route-target, not vice versa.
Tim.
cjurado77
Community Member
I am trying to make something similar to this configuration into two diferents 7600 Cisco Routers. I'll try to explain myself.
I would like that VRF-100, which is configured in 7600-1, learn some routes from VRF-300, which is cofigured in 7600-2. Also, I would like that VRF-300 lear default route from VRF-100. Its some kind of hub&spoke configuration.
I've configured the following:
*** Configuration in 7600-1:
ip vrf VRF-100
  rd 65001:100
  route-target export 65001:100
  route-target import 65001:100
  route-target import 65001:200
router bgp 65001
   address-family ipv4 vrf VRF-100
      redistribute ospf 100 vrf VRF-100
      default-information originate
   exit-address-family
router ospf 100 vrf VRF-100
   redistribute bgp 65001 subnets
*** Configuration in 7600-2:
ip vrf VRF-300
   rd 65001:300
   export map test-01
   route-target export 65001:300
   route-target import 65001:300
router bgp 65001
   address-family ipv4 vrf VRF-300
      redistribute ospf 300 vrf VRF-300
   exit-address-family
router ospf 300 vrf VRF-300
ip access-list standard test-01
   permit 3.3.3.0 0.0.0.255
route-map test-01 permit 10
   match ip address test-01
   set extcommunity rt 65001:200 additive
interface Loopback300
ip vrf forwarding VRF-300
ip address 3.3.3.1 255.255.255.0
ip ospf 300 area 0
end
The 7600-1 router is learning the default gateway from OSPF from another device, and I'm redistributing it into bgp. But 7600-2 does not learn default route.
7600-1#sh ip route vrf VRF-100 0.0.0.0
Routing Table: VRF-100
Routing entry for 0.0.0.0/0, supernet
  Known via "ospf 100", distance 110, metric 1, candidate default path
  Tag 100, type extern 2, forward metric 100
  Redistributing via bgp 65001
  Last update from X.X.X.X on VlanXXX, 1d23h ago
  Routing Descriptor Blocks:
  * X.X.X.X, from Y.Y.Y.Y, 1d23h ago, via VlanXXX
      Route metric is 1, traffic share count is 1
      Route tag 100
7600_22A_A#
7600-2#sh ip route vrf VRF-300 0.0.0.0
Routing Table: VRF-300
% Network not in table
By the other hand, 7600-1 is not learning 3.3.3.0, which is beeing distributed by ospf 300 in 7600-2, redistributed into bgp and exported through the export map in the vrf configuration.
I thought this should work, but it is not working, so I might be doing something incorrectly.
I can not guess where is the problem. Can anybody help me?
Hi There
Default-Route from OSPF can't be redistributed into BGP by virtue of design. In a hub and spoke scenario we would need to originate the default route in the MP-iBGP on the Hub Router.
Is the Network 3.3.3.0 on 7600-2 an InterArea or External Network Type LSA. We would need to add the keywords "match internal 1 internal 2 external" while redistributing OSPF to BGP under MP-iBGP config as by default only LSA Type 1 are redistributed.
Thanks & Regards
Vaibhava Varma
Hi Vibhava,
I solved it just adding a route-map in the redistribution from ospf to bgp.
   redistribute bgp 65001 subnets route-map DG
route-map   DG permit 10
   match ip address prefix-list DG
   set local-preference 150
ip   prefix-list DG permit 0.0.0.0/0
It's more or less what you say in your post. My default gateway was an external network type (it was a static route redistributed into ospf), but instead of adding all external routes into bgp, I add just the default.
Thank you so much for your explanation, because I didn't understand at all why the redistribution didn't work without the route-map. Now I understand it better 😃
Cristina
Even 11 years after this thread is very worthful to learn how to do selective vrf import export. When using IOS XR, you should use import and export the usual rd as well:
RP/0/0/CPU0:XR2#sh runn form vrf VPN_D
Tue Jun 30 17:23:33.731 UTC
vrf VPN_D
vrf VPN_D address-family ipv4 unicast
vrf VPN_D address-family ipv4 unicast import route-policy ACCEPT-RT(100, 1)
vrf VPN_D address-family ipv4 unicast import route-target 102:202
vrf VPN_D address-family ipv4 unicast export route-policy EXPORT-RT-R8-LO100(100, 1)
vrf VPN_D address-family ipv4 unicast export route-target 102:202
In this case when importing you have to include as well the RD at the route-policy because it will filter all the rt except the one mentioned at the route-policy. When exporting you just have to add the rt additive.
route-policy ACCEPT-RT($a, $b)
  if (extcommunity rt matches-any (102:202)) or extcommunity rt matches-any ($a:$b) then
    pass
  endif
end-policy
route-policy EXPORT-RT-R8-LO100($a, $b)
  if destination in R8-LO88 then
    set extcommunity rt ($a:$b) additive
  endif
end-policy
I am sure that someone can do it simpler, but with this config I managed to set end to end connectivity bewteen both VRFs.
Hope this helps and thanks for your feedback on this.
Roberto
