ebgp mpls question
marcusbrutus
Hi Experts,
I've been struggling with this setup and couldn't get it to work.
The idea basically is to establish ebgp mpls peering between two different AS.  There shouldn't be any global table entries.
I am able to get as far as the vpnv4 vrf summ showing as active but it can't seem to peer successfully.  I am able to do "ping vrf test ip 192.168.2.2 source 192.168.1.1 successfully from router1 so I am sure there is no issue in connectivity between loopbacks.
Please see below config of R1.
ip vrf test
rd 10:100
route-target import 20:200
route-target export 10:100
int l0
ip vrf forwarding test
ip add 192.168.1.1 255.255.255.0
int f0/0
ip add 1.1.1.1 255.255.255.0
route ospf 10 vrf test
network 1.1.1.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
router bgp 10
neighbor 192.168.2.2 remote-as 20
neighbor 192.168.2.2 update-source l0
    address-family vpnv4
     neighbor 192.168.2.2 active
     neighbor 192.168.2.2 next-hop-self
     neighbor 192.168.2.2 send-community both
     address-family ipv4 vrf test
     neighbor 192.168.2.2 ebgp-multihop 255
     neighbor 192.168.2.2 activate
Same setup on peer router only with different IPs specified ofcourse.
I saw some configs for ebgp mpls but the loopback address was not included in the vrf.
Would really appreciate anyone's help on this.
Thanks in advance.
As Vaibhava mentioned. the following needs to be added.
     neighbor 192.168.2.2 remote-as 20  update-source lo0
This is when you don't use the loopbacks for the BGP peering and you use the physical interface IP. In your example
it would the following config assuming that the peer ip is 1.1.1.2. This will use the following interface for eBGP.
int f0/0
     neighbor 1.1.1.2 remote-as 20
     neighbor 1.1.1.2 ebgp-multihop 255
     neighbor 1.1.1.2 activate
HTH,
Kishore
Please rate if helps
Vaibhava Varma
Level 4
Level 4
Hi marcusbrutus
Please add the "update-source lo0 " for the neighbour statement under VRF context on both routers to solve your issue.
The Problem here is that we are trying to peer over Loopback IPs but the Source of BGP Open message is going to be the interface ip which is a mismatch and keeping the session active.
Hope this answers your query.
Varma
int f0/0
HTH,
Kishore
