Entropy Label Capability
sbattula301
Community Member
In Cisco ASR 9006, I had enabled  Entropy Label,  under mpls  ldp  "entropy-label" ,   commit goes through fine. but I don't see ASR9006 is generating  ELC TLV for its own system FEC.
  7x50 ------------------------ASR9006 -----------------------7x50
  (10.20.1.2)                   (10.20.1.8)                          (10.20.1.3)
In the above both 7x50 are enabled with ELC.   they are generating ELC for their system FECs'
Logs:
191 2016/06/21 20:46:50.15 UTC MINOR: DEBUG #2001 Base LDP
"LDP: LDP
Send Label Mapping packet (msgId 5) to 10.20.1.8:0
Protocol version = 1
Label 262143 advertised for the following FECs
Prefix Address Family = 1 Prefix = 10.20.1.2/32
Entropy Label Capability (U bit = 1, F bit = 1)
But from cisco asr 9006 version 5.3.2 , I don't see ELC TLV being sent.
179 2016/06/21 20:46:49.80 UTC MINOR: DEBUG #2001 Base LDP
"LDP: LDP
Recv Label Mapping packet (msgId 19) from 10.20.1.8:0
Label 3 advertised for the following FECs
Prefix Address Family = 1 Prefix = 10.20.1.8/32   --------------------> NO Entropy Label Capability  TLV received
8 Replies 8
Nagendra Kumar Nainar
It seems this is not supported in ASR9k yet. This appears to be supported on CRS.
-Nagendra
As per below doc
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/mpls/command/reference/b_mpls_cr42asr9k/b_mpls_cr42asr9k_chapter_01.html#wp2525564653
it is supported in ASR9K from 5.3.2 onwards, but  that seems to be not working.
Srinivas
I think it should be a documentation issue. Entropy label was targetted for CRS (P routers) on 5.3.2 as mentioned in the document. The CLI is available but the feature is not supported in ASR9k.
-Nagendra
Looks like in  CRS also this support is not there.  We verified with CRS latest version.
Srinivas
So what’s the conclusion on this one please?
Do Cisco ISP products support entropy labels or not? And if yes is it compatible with other vendors?
Thank you
adam
adam
Vinit Jain
Did you try flapping the LDP neighbor. what is the XR version you are running
--Vinit
I flapped the session , still I don't see Cisco Sending ELC Tlv.
XR Version 5.3.2
RP/0/RSP1/CPU0:ios#show version
Sat Jun 25 16:01:45.739 UTC
Cisco IOS XR Software, Version 5.3.2[Default]
Copyright (c) 2015 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 1.06(20120210:003513) [ASR9K ROMMON],
ios uptime is 1 hour, 21 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-5.3.2/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (MPC8641D) processor with 4194304K bytes of memory.
MPC8641D processor at 1333MHz, Revision 2.2
ASR 9006 4 Line Card Slot Chassis with V2 AC PEM
4 Management Ethernet
40 GigabitEthernet
219k bytes of non-volatile configuration memory.
977M bytes of compact flash card.
67988M bytes of hard disk.
1605616k bytes of disk0: (Sector size 512 bytes).
1605616k bytes of disk1: (Sector size 512 bytes).
Configuration register on node 0/RSP0/CPU0 is 0x102
Boot device on node 0/RSP0/CPU0 is disk0:
Package active on node 0/RSP0/CPU0:
iosxr-mcast, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-mcast-5.3.2
Built on Tue Sep 1 02:55:08 UTC 2015
By iox-lnx-006 in /auto/srcarchive16/production/5.3.2/asr9k/workspace for pie
asr9k-mcast-supp, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-mcast-supp-5.3.2
asr9k-mcast-px, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-mcast-px-5.3.2
Built on Tue Sep 1 02:55:24 UTC 2015
asr9k-fpd, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-fpd-5.3.2
Built on Tue Sep 1 04:01:13 UTC 2015
asr9k-fpd-px, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-fpd-px-5.3.2
Built on Tue Sep 1 04:01:49 UTC 2015
iosxr-mpls, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-mpls-5.3.2
Built on Tue Sep 1 02:54:54 UTC 2015
asr9k-mpls-px, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-mpls-px-5.3.2
Built on Tue Sep 1 02:55:07 UTC 2015
iosxr-infra, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-infra-5.3.2
Built on Tue Sep 1 02:49:04 UTC 2015
iosxr-fwding, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-fwding-5.3.2
iosxr-routing, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-routing-5.3.2
Built on Tue Sep 1 02:49:06 UTC 2015
iosxr-diags, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-diags-5.3.2
Built on Tue Sep 1 02:49:07 UTC 2015
iosxr-ce, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-ce-5.3.2
iosxr-common-pd-fib, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-common-pd-fib-5.3.2
asr9k-cpp, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-cpp-5.3.2
Built on Tue Sep 1 02:49:08 UTC 2015
iosxr-gcp-fwding, V 5.3.2[Default], Cisco Systems, at disk0:iosxr-gcp-fwding-5.3.2
Built on Tue Sep 1 02:49:13 UTC 2015
asr9k-os-mbi, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-os-mbi-5.3.2
Built on Tue Sep 1 02:51:40 UTC 2015
asr9k-base, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-base-5.3.2
Built on Tue Sep 1 02:49:18 UTC 2015
asr9k-fwding, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-fwding-5.3.2
Built on Tue Sep 1 02:49:35 UTC 2015
asr9k-ce, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-ce-5.3.2
Built on Tue Sep 1 02:49:36 UTC 2015
asr9k-diags-supp, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-diags-supp-5.3.2
Built on Tue Sep 1 02:49:40 UTC 2015
asr9k-scfclient, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-scfclient-5.3.2
Built on Tue Sep 1 02:49:41 UTC 2015
asr9k-mini-px, V 5.3.2[Default], Cisco Systems, at disk0:asr9k-mini-px-5.3.2
Built on Tue Sep 1 02:52:40 UTC 2015
Configuration register on node 0/RSP1/CPU0 is 0x2102
Boot device on node 0/RSP1/CPU0 is disk0:
Package active on node 0/RSP1/CPU0:
Boot device on node 0/0/CPU0 is mem:
Package active on node 0/0/CPU0:
RP/0/RSP1/CPU0:ios#
raichmayer
Frequent Visitor
Frequent Visitor
As this is still not supported, may I ask:
1) if there is any Roadmap for LDP-Entropy on the ASR9k?
2) Would this also mean that LDP changes from independent to ordered distribution mode?
3) Will it also be available for BGP-LU to have Entropy for seamless MPLS?
