EoMPLS on campus MAN
amaitre
I have Layer-2 communication problem to solve to let 2 servers communicate over a routed core. My core and distribution switches are 6500 with sup720-3b. I figured out that the only way I could do that without having to pull a physical link in between was to use EoMPLS.
That's how it's configured
DIST_1-G1/1 <--> G1/1-CORE-G1/2 <--> G1/1-DIST_2
DIST_1 configuration:
mpls label protocol ldp
interface Loopback0
ip address 10.1.1.3 255.255.255.255
interface GigabitEthernet1/1
ip address 192.168.1.2 255.255.255.252
tag-switching ip
interface Vlan174
no ip address
mpls l2transport route 10.1.1.4 174
DIST_2 configuration:
interface Loopback0
ip address 10.1.1.4 255.255.255.255
ip address 192.168.1.6 255.255.255.252
tag-switching ip
interface Vlan174
no ip address
mpls l2transport route 10.1.1.3 174
CORE configuration:
ip address 192.168.1.1 255.255.255.252
tag-switching ip
interface GigabitEthernet1/2
ip address 192.168.1.5 255.255.255.252
tag-switching ip
the VLAN 174 is created on both distributions and all 3 have OSPF configured and I can ping loopbacks.
Attached are a few show commands
Can anyone tell me what is wrong with my setup?
Antoine
mheusinger
Level 11
Level 11
It looks as if no labels are assigned, which often is because CEF is not enabled. Can you additionally post
show ip cef 10.1.1.3
show ip cef 10.1.1.4
show mpls forwarding-table
One issue could be CEF not working correctly, but it should be enabled on the 6500 by default (Router(config)#ip cef).
Hope this helps! Please rate all posts.
Regards, Martin
