03-03-2005 07:45 PM
I've a mixture of EoMPLS & L3VPN traffic that needs to traverse an MPLS Core TE.
Can anyone advise how to do traffic classification and QOS for the EoMPLS traffic across this TE?
Thks!
03-07-2005 01:08 AM
as long as your switches trust what the customer is sending you i.e. PREC those values will be mapped into EXP bits just the same as your L3 connections work.
03-08-2005 10:05 PM
suppose the CE connection is a DOT1Q link to the a 7600 and comprise of both L3VPN; the 7600 will classify all EXP bits accordingly. Could you advise how to do it.
Thks.
03-09-2005 12:43 AM
its automatic. cos---> dscp then dscp--> exp maps are already there for you. To see these mappings do
show mls qos maps (then either cos-dscp or dscp-exp)
