EoMPLS vlan mode troubleshooting steps
gaurav_saxena
What would be the specific troubleshooting steps in VLAN Mode Scenarios using specific VLAN tags.How can we use VLAN tags for troubleshooting EoMPLS. I understand that we can use end to end LSP check, VC status in port mode and vlan mode.
Cheers
Gaurav
spremkumar
Level 9
Level 9
hi
i would like to add one more point too whichs the MTU size which gets in automatically on the vlan interfaces when you configure them for either EWS or VPLS,by default it takes 9216 and on the other end may be something else which also block bringing the VC operationally up.
regds
Thanks Prem,
What i was looking if there is any way we can use Vlan tags for doing any type of troubleshooting?
Cheers
Gaurav
