EVPN - Multipoint Segment Routing
Tom Sverre Pedersen
Frequent Visitor
Frequent Visitor
Hello, I'm trying to configure EVPN for L2VPN traffic. I already have SR-MPLS basic configure with ISIS and BGP.
I want to make a L2VPN from my distribution switches using EVPN. I have two Core switches (ASR 9903), they are setup with:
  • ISIS
  • Segment Routing MPLS
  • BGP (Route Reflector)
  • BNG
I have read a lot around EVPN and SR. Many of the examples are showing advanced MPLS TE stuff, what I want now is just to get a EVPN Multipoint up and running and then later play with SR MPLS-TE. Can some one show me some configuration examples?
/Tom
AnthonySylvester
Check this out for point to point EVPN
Check this out for point to multi-point EVPN
Here is a VPWS example:
CE23 - PE3 - <P network> - PE4 - CE24
PE3 connects to CE23 using G0/0/0/2 and the L2VPN will use G0/0/0/2.100 l2transport  (the same is configured for PE4 to CE24)
RP/0/0/CPU0:PE3#sh run int g0/0/0/2.100
Tue Mar 22 17:37:40.486 UTC
interface GigabitEthernet0/0/0/2.100 l2transport
 description To L2VPN_CE23
 dot1q vlan 100
RP/0/0/CPU0:PE3#sh run l2vpn
Tue Mar 22 17:37:55.955 UTC
l2vpn
 pw-class EoMPLS-PWCLASS
  encapsulation mpls
 xconnect group XCONNECT_GROUP
  p2p CE24
   neighbor ipv4 1.1.1.14 pw-id 1234
RP/0/0/CPU0:PE3#
RP/0/0/CPU0:PE4#sh run int g0/0/0/2.100
Tue Mar 22 17:39:57.277 UTC
 description To L2VPN_CE24
 dot1q vlan 100
RP/0/0/CPU0:PE4#sh run l2vpn
Tue Mar 22 17:40:14.115 UTC
l2vpn
  encapsulation mpls
  p2p CE23
   neighbor ipv4 1.1.1.13 pw-id 1234
RP/0/0/CPU0:PE4#
Here is how you can verify that your L2VPN is up:
RP/0/0/CPU0:PE3#sh l2vpn xconnect
Tue Mar 22 17:44:34.428 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready, (PP) = Partially Programmed
XConnect                   Segment 1                       Segment 2
Group      Name       ST   Description            ST       Description            ST
XCONNECT_GROUP
           CE24       UP   Gi0/0/0/2.100          UP       1.1.1.14        1234   UP
RP/0/0/CPU0:PE3#
RP/0/0/CPU0:PE4#sh l2vpn xconnect
Tue Mar 22 17:45:01.446 UTC
XCONNECT_GROUP
           CE23       UP   Gi0/0/0/2.100          UP       1.1.1.13        1234   UP
RP/0/0/CPU0:PE4#
Let me know if this helps!
-Anthony Sylvester
** Please remember to mark this post if it was helpful. **
Anthony Sylvester
