08-19-2022 01:11 AM
I have the following set up. R1 , R2 and R3 are CSR routers. And running isis.
I have configured 'fast-reroute per-prefix level-2 all' on R1 but I do not see the 'repair path' for 2.2.2.2(R2's loopback) and 3.3.3.3(R3's loopback). What else should I configure so that R1 will have repair path for 2.2.2.2 and 3.3.3.3?
R1#show ip route 3.3.3.3
Routing entry for 3.3.3.3/32
Known via "isis", distance 115, metric 20, type level-2
Redistributing via isis 1
Last update from 100.10.30.3 on GigabitEthernet2, 00:00:55 ago
Routing Descriptor Blocks:
* 100.10.30.3, from 3.3.3.3, 00:00:55 ago, via GigabitEthernet2
Route metric is 20, traffic share count is 1
R1
R2-------------R3
R1
ipv6 unicast-routing
int gi1
ip address 100.10.20.1 255.255.255.0
ipv6 address 2001:12::1/128
ip router isis 1
ipv6 router isis 1
no sh
int gi2
ip address 100.10.30.1 255.255.255.0
ipv6 address 2001:13::1/128
ip router isis 1
ipv6 router isis 1
no sh
int lo0
ip address 1.1.1.1 255.255.255.255
ipv6 address 1::/128
ip router isis 1
ipv6 router isis 1
router isis 1
metric-style wide
net 49.0001.1111.1111.1111.00
exit
R2
int gi1
ip address 100.10.20.2 255.255.255.0
ipv6 address 2001:12::2/128
ip router isis 1
ipv6 router isis 1
no sh
int gi3
ip address 100.20.30.2 255.255.255.0
ipv6 address 2001:23::2/128
ip router isis 1
ipv6 router isis 1
no sh
int lo0
ip address 2.2.2.2 255.255.255.255
ipv6 address 2::2/128
ip router isis 1
ipv6 router isis 1
exit
router isis 1
metric-style wide
net 49.0002.2222.2222.2222.00
exit
R3
int gi2
ip address 100.10.30.3 255.255.255.0
ipv6 address 2001:13::3/128
ip router isis 1
ipv6 router isis 1
no sh
int gi3
ip address 100.20.30.3 255.255.255.0
ipv6 address 2001:23::3/128
ip router isis 1
ipv6 router isis 1
no sh
int lo0
ip address 3.3.3.3 255.255.255.255
ipv6 address 3::3/128
ip router isis 1
ipv6 router isis 1
exit
router isis 1
metric-style wide
net 49.0003.3333.3333.3333.00
exit
Sachin
Solved! Go to Solution.
08-19-2022 01:50 AM
i would check the config - if they connected back to back (I would re-visit the IP address configured for the p2p IP)
check do you have first ISIS neighbourship before you go next level :
#show isis neighbors
08-19-2022 08:23 AM - edited 08-19-2022 08:35 AM
Hi @sachin30720041 ,
As per the following document, make sure you configure the isis interfaces as p2p.
Loop-Free Alternate (LFA) Fast Reroute (FRR) can protect paths that are reachable through an interface only if the interface is a point-to-point interface.
When a LAN interface is physically connected to a single neighbor, you should configure the LAN interface as a point-to-point interface so that it can be protected through LFA FRR.
08-19-2022 01:50 AM
