Features mlppp Cisco asr 9006
the PPP Multilink (MLPPP) feature does not seem to be on the devices with IOS XR, except for the CRS, do you confirm?
Giuseppe Tomasicchio
2 Accepted Solutions
Francesco Molino
I was answering yes but i had a doubt and verified on Cisco IOS Feature navigator.
Based on the following output, i can confirm yes it's only on CRS for ios xr based device.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Just for information as we discussed on private chat. Asr9k doesn't seem to support this feature.
Francesco
Francesco Molino
Francesco
thanks a lot, but which version of cisco asr 9xxx would be good for multilink ppp features?
I should have migrated the services that are currently on cisco asr 1002 to cisco asr 9006.
you can help me, thanks
Cisco IOS XR Software, Version 6.4.2[Default]
Copyright (c) 2018 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 0.76(c) 1994-2012 by Cisco Systems, Inc.
ios uptime is 33 weeks, 5 days, 21 hours, 15 minutes
System image file is "disk0:asr9k-os-mbi-6.4.2/0x100305/mbiasr9k-rsp3.vm"
cisco ASR9K Series (Intel 686 F6M14S4) processor with 12582912K bytes of memory.
Intel 686 F6M14S4 processor at 2127MHz, Revision 2.174
ASR 9006 4 Line Card Slot Chassis with V2 AC PEM
have this version okay?
Francesco
