FRR with Auto tunnel Primary and Explicit Backup
menon.sunil
Is it possible to setup a Automesh for Primary TE tunnel and explicit
backup tunnels for FRR.I was trying to configure this,but FRR doesnt
seem to be working,though both the tunnels are up. when I break the
primary path,the traffic does on the explicit tunnel but does not
switchover once the primary path is restored.The FRR is not working.Any
inputs would be of great help.
Sunil
6 Replies 6
swaroop.potdar
Level 7
Level 7
Can you please send your configurations, may be we can take it ahead on unicast.
HTH-Cheers,
Swaroop
bjornarsb
Level 4
Level 4
You might be aware of this but check the following command:
tunnel mpls traffic-eng priority setup-priority [hold-priority]
Configures setup and reservation priority for a tunnel.
The setup-priority argument is the priority used when signaling an LSP for this tunnel to determine which existing tunnels can be preempted.
Valid values are from 0 to 7. A lower number indicates a higher priority. An LSP with a setup priority of 0 can preempt any LSP with a non-0 priority.
The hold-priority argument is the priority associated with an LSP for this tunnel to determine if it should be preempted by other LSPs that are being signaled.
Valid values are from 0 to 7, where a lower number indicates a higher priority.
Bjornarsb
I have done that.I changed the priority 7 7 o n the autotemplate and manually set the backup tunnels to priority 1 1 on all the routers....it still does not switchover to the primary lsp after the primary link has been restored.
Sunil
Hi again,
a lower number indicates a higher priority so I think you should change to 1 1 for the autotemplate and 7 7 for the backup tunnel to allow preemption.
Bjornarsb
oettls
Hi Sunil,
the switchover back to the primary path is triggered by the TE reoptimization process. The default for periodic reoptimization is 3600s (== 1h) ...
You can check if it's the reason for not switching back by manually triggering the process on the tunnel headend:
router#mpls traffic-eng reoptimize
If you want to switch back faster you can check out 'mpls traffic-eng reoptimize events link-up' - but this could cause some oscillation ...
cheers,
Stefan
The problem when I configure Automesh with Explicit backup tunnel,the FRR promotion does not happen.
Test_rtr1#show mpls traffic-eng tunnels property backup-tunnel brief
Signalling Summary:
LSP Tunnels Process: running
Passive LSP Listener: running
RSVP Process: running
Forwarding: enabled
auto-tunnel:
backup Disabled (0 ), id-range:65436-65535
onehop Disabled (0 ), id-range:65336-65435
mesh Enabled (10), id-range:1000-2000
Periodic reoptimization: every 10 seconds, next in 2 seconds
Periodic FRR Promotion: Not Running
Periodic auto-bw collection: disabled
TUNNEL NAME DESTINATION UP IF DOWN IF STATE/PROT
***USED AS BACKUP FOR AUTO-T... 10.0.0.43 - PO2/0/0 up/up
Displayed 1 (of 18) heads, 0 (of 16) midpoints, 0 (of 12) tails
Test_rtr1#
Sunil
