08-21-2005 03:48 PM
I have implemented MPLS VPN. Currently running as a full mesh connectivity. I
need to implement and configure a hub and spoke connectivity due to the
business requirement.
I have 4 spokes and 1 hub. For each spokes, they shouldn't communicate
with spoke, only to hub and vice-versa.
What is the appropriate and best practise for me to implement and configuring for such scenario?
Appreciate your feedbacks and opinion.
regards,
maher
Solved! Go to Solution.
08-22-2005 04:43 AM
ok keep all your config in as it is just now. The only issue (personal one I believe) is that you shall be using the same RD everywhere but that shouldnt matter. On your hub site add under the vrf something like Route-target export 99:1. On a your spoke sites add route-target export 99:2 then on the other spoke site route-target export 99:3 until you do them all to 99:x. Then go back to the hub site and do route-target import 99:2 all the way through to x. You can now remove your original route-targets and all shall be fine. A cleaner method would be to completely remove the vrf but thats prolly too much hassle and downtime for your liking :-)
08-21-2005 10:52 PM
The best method would be play with the RTs at all your sites if you want a Star network. or else you colud run full mesh MPLS and have IPSec from Hub to spoke.
08-23-2005 03:43 PM
thanks for the info. quite intersting to play with RT's :)
regards,
maher
08-22-2005 04:43 AM
08-23-2005 03:47 PM
Thanks for the tips given. Let me try to see on the operationl first! :P Yiks. Will let you know the result.
regards,
maher
