GRE, IRB and VRF
I have my current network where I am doing bridging over WAN using GRE and IRB. Works perfectly fine. I have a additional requirement whereby I need to use duplicate IP addressing scheme on the same router. I was looking at VRFs for such a implementation. I have seen a scenario on Cisco's site whereby they are implementing GRE Tunnel with VRF configuration. But is it possible to run bridging, GRE and VRF together. Any issues.
carenas123
Level 5
Level 5
I think it is possible without any issues. Please refer the following link for some information...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/switch_c/xcprt4/xcdtagc.htm#xtocid1953813
