Help in configuring MPLS
ajkhader123
Hi All,
I have an MPLS connection from ISP, I want to logically divide into two by creating subinterface, how to achieve this.
csco10716389
Please describe your requirement in bit detail.I don't understand the motive of doing this.
shivlu jain
Level 5
Level 5
i think you want to create in subinterface because you are having one physical interface and want to use two sub interface one for isp and one for lan.
So simpley plug your router interface to switch and isp interface also on switch if you are getting ethernet. Now on run the command
int fa0/0.10
encapsulation dot1q 10
ip address isp ip
int fa0/0.11
encapsulation dot1q 11
ip address lan ip
regards
shivlu jain
