How to capture ethernet Frames with Ethertype 0x8847 & 0x8848 on ISR
Jerems
Hi dear community,
According to you, what is the best way to capture MPLS traffic flowing between two ISR ?
Does EPC  provide a way to do so from the router itself ?
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-embedded-packet-capture/116045-productconfig-epc-00.html
Does a switch in between, with port mirroring enabled, mandatory ?
Best Regards,
Jerems
8 Replies 8
Port mirror not need embedded packet capture'
The command list "mirror" but that not meaning port mirror.
Do EPC and I will check my notes about other way to capture mpls without using wireshark.
Can I know what is ISR platform you have excatly
MHM
I know that Port mirror is not mandatory as ECP is a different embedded feature on Cisco ISR. Anyway, It looks like ECP only works with IPv4/v6 payload.
My post aimed to mention the different ways to capture MPLS packets . First one could be ECP and the second one is to perform a simple port mirroring (from a switch connected to the ISR "targeted interface".
Ok  understood.
You can use
Debug platfrom packet-tracer enable
Debug platform condition mpls <> ingress/egress
I think this also help you to detect mpls packet.
MHM
I will give it a try tonight with these interesting commands.
Thanks a lot @MHM Cisco World !
I'm talking about ISR 111X series
Torbjørn
Yes, you should be able to achieve this with EPC. You can find instructions as to how to perform EPC here: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/epc/configuration/xe-16-6/epc-xe-16-6-book.pdf
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Jerems
Not sure if EPC works with Ethernet frames that transports IPv4/IPv6 payload only.
