How to implement pim-ssm over mpls with sparse-mode and test by notebook from vlc player ?
6 Replies 6
Vaibhava Varma
Level 4
Level 4
Hi PlawanSai
Implementing PIM SSM over MPLS Backbone will not require any RP in the Core and SSM-MAPs would be required at the edge for mapping Multicast Stream to Source which the receivers would be explicitly joining.The Core Interfaces ( and Access Interaces would be enabled with PIM-SM as usual)
Global Config
ip igmp ssm-map static XYZ(Stream Name) A.B.C.D(Stream Unicast Source)
ip access-list standard XYZ
permit E.F.G.H(Stream Multicast IP)
Interface Config
L3-Gateway Interace for LAN users
ip igmp static-group E.F.G.H source ssm-map
Regarding the VLC Player Testing I am not very sure how to test it..Hope the experts around help you on same..I always test it using Static IGMP Groups on the L3-LAN Gateway Interface but in that case I don't use SSM -MAP..SO if in this case we have the SSM-MAP enables I think if we can somehow make the VLC send a request for Multicast Stream in question it shoud work..Below is some points I found online for "using VLC Player for multicast testing"
Using UDP to stream to multiple recipients
locate a suitable video file (e.g. “file.avi”) and open a command prompt (windows) or terminal window (Linux).  Change to the directory where file.avi exists.
On the server enter:
vlc -vvv file.avi –sout udp:239.0.0.1 –ttl 12 –loop
NOTE:  If VLC is not in your path, you need to add it.  To do this, type “set” to show your existing path, e.g.
path=c:\php;C:\Perl\site\bin;C:\Perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ZipGenius 6\;C:\usr\bin;C:\Program Files\SSH Communications Security\SSH Secure Shell\
Now add the VLC directory to the path, with “set path”:
set path=c:\php;C:\Perl\site\bin;C:\Perl\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ZipGenius 6\;C:\usr\bin;C:\Program Files\SSH Communications Security\SSH Secure Shell\;C:\Program Files\VideoLAN\VLC\
On the client(s) enter:
vlc -vvv udp:@239.0.0.1
OR from the VLC player:
Media > Open Network  (then choose UDP and enter multicast address).
Hope this provides some insight to your query and help to move forward in your testing..
Varma
shivjain
hi
Please check the below link for full deployment of SSM in SP cloud
http://www.mplsvpn.info/2009/05/deploying-testing-of-ssm-in-service.html
Also in vlc simply on one laptop you have to announced it as server in vlc options itself and others will join that group.
regards
shivlu jain
Thank you very much. But now I would like to implement in global not in vrf. I configured in vrf is work.
yes it will work. Because SSM is for your global.
http://www.mplsvpn.info/2009/02/implementation-of-ssm.html
regards
shivlu jain
Now, My lab has 3 PE (PE1 -- PE2 -- PE3) and test by vlc connected to PE1 & PE3 is not work, I configured below:
PE1# and PE2, PE3 is same command changed interface.
ip multicast-routing
interface Loopback0
ip pim sparse-mode
ip igmp version 3
interface GigabitEthernet1/0/0
description to PE2
ip pim sparse-mode
ip igmp version 3
interface Vlan40
description to notebook with vlc
ip pim sparse-mode
ip igmp version 3
ip pim ssm range 39
access-list 39 permit 239.0.0.0 0.255.255.255
