02-12-2006 06:44 PM
my company supplies metro-ethernt over MPLS.i am tring to implement layer vpn for a customer using ospf on the CE router area 1 traffic will go via my MPLS network and out to another CE router in area 0. I am unable to ping vrf network across PE routers
02-12-2006 07:20 PM
Are you seeing all the required routes from all CEs on the PEs ?
Would you be able to post a few more details ? What works and what does not ?
Paresh
02-13-2006 12:01 AM
Dear
Checking the vrf routing tabel in both sides (Show ip route vrf ZYX ) if the routes is not exist check the redistribution between OSPF-MGBGP Versa MPBGP-OSPF
Best Regards,
Mounir Mohamed
