10-09-2009 04:50 AM
Running inter-as MP-BGP multicast between PE's using MDT under the VRF without a problem. Problem is GRE dynamic tunnel is built using my loopback interface in the global routing table and not in the VRF. All PIM/MSDP is done on loopback interface within the VRF between PE's so when i block AUTO-RP messages (224.0.1.39/224.0.1.40) between PE's, AUTO-RP messages is still exchange on loopback interface in the global since MDT is using that to build the GRE dynamic tunnel. Is it possible to be selective on which interface MDT uses to build dynamic GRE tunnel between PE's?
Is manual GRE tunnel the way forward?
Please let me know if you need clarification
Configs.
10-09-2009 08:24 AM
after researching this i now undertsand that the loopback in the global is used because that's what BGP uses to established adjacency between PE's. so MDT uses that.
10-14-2009 06:45 PM
Hi Francisco,
MDT group is used to encapsulate customer multicast traffic so it's part of the SP domain or the global routing.
In case of Inter-AS Option-B, you need to use the RPF-vector PIM extension so you don't have to redistribute the PE loopbacks between both AS.
Laurent.
10-22-2009 05:39 AM
As far as I can remember you can do this by choosing a bgp next-hop option located in VRF configuration.
for instance:
ip vrf a
bgp next-hop Loopback10
Hope it helps!
Kind regards,
Dani
02-26-2010 11:25 AM
Are there featrue in Cisco to separate IGP routing for multicast routing and unicast routing table?
03-01-2010 08:02 PM
We support MTR on 7600. With MTR, you have a dedicated table for RPF check and you decide which routes from the unicast tables you want to import on the RPF table. But you have only one RPF table even if you have several unicast RIB (or topologies)
http://www.cisco.com/en/US/docs/ios/12_2sr/12_2srb/feature/guide/srmtrdoc.html#wp1053994
Other than that, you will have to use static mroute.
Laurent.
