interworking of segment-routing and mpls ldp
sachin30720041
Hello All,
I have a following set up. Segment-routing is enabled on XRV1, XRV2 and XRV3. And ldp is enabled on csr4 and csr5.
I have configured mapping server for CSR4's and CSR5's loopback addresses. BGP VPNV4 is enabled between XRV1 and XRV3.
vrf1 is configured on XRV1 and XRV3. I am not able to ping from vrf1's loopback1 on XRV1 to loopback1 of VRF1 on XRV3.
XRV1#ping vrf vrf1 33.33.33.33 source 11.11.11.11
Wed Sep 7 22:24:18.726 UTC
Sending 5, 100-byte ICMP Echos to 33.33.33.33, timeout is 2 seconds:
Success rate is 0 percent (0/5)
XRV1-----CSR4-----CSR5---------XRV2----XRV3
XRv1
vrf vrf1
address-family ipv4 unicast
export route-target 1:1
import route-target 3:3
exit
segment-routing
mapping-server
prefix-sid-map
address-family ipv4
4.4.4.4/32 4
5.5.5.5/32 5
int lo1
vrf vrf1
ip address 11.11.11.11 255.255.255.255
exit
router bgp 13
exit
address-family vpnv4 unicast
exit
neighbor-group group1
remote-as 13
update-source lo0
exit
neighbor 3.3.3.3
use neighbor-group group1
vrf vrf1
rd 1:1
network 11.11.11.11/32
exit
int gi0/0/0/1
ipv4 address 100.10.40.1 255.255.255.0
no sh
int lo0
ipv4 address 1.1.1.1 255.255.255.255
mpls ldp
exit
router isis 1
net 49.0001.1111.1111.1111.00
is-type level-2
distribute link-state
mpls ldp auto-config
metric-style wide
segment-routing mpls
segment-routing prefix-sid-map advertise-local
router-id lo0
exit
int gi0/0/0/1
point-to-point
exit
int lo0
prefix-sid index 1
exit
CSR4
int gi1
ip address 100.10.40.4 255.255.255.0
ip router isis 1
isis network point-to-point
no sh
int gi2
ip address 100.40.50.4 255.255.255.0
ip router isis 1
no sh
int lo0
ip address 4.4.4.4 255.255.255.255
ip router isis 1
router isis 1
net 49.0004.4444.4444.4444.00
is-type level-2
mpls ldp autoconfig
metric-style wide
exit
CSR5
int gi1
ip address 100.20.50.5 255.255.255.0
ip router isis 1
no sh
int gi2
ip address 100.40.50.5 255.255.255.0
ip router isis 1
no sh
int lo0
ip address 5.5.5.5 255.255.255.255
ip router isis 1
router isis 1
net 49.0005.5555.5555.5555.00
is-type level-2
mpls ldp autoconfig
metric-style wide
exit
XRV2
int gi0/0/0/0
ipv4 address 100.20.30.2 255.255.255.0
no sh
int gi0/0/0/1
ipv4 address 100.20.50.2 255.255.255.0
no sh
int lo0
ipv4 address 2.2.2.2 255.255.255.255
router isis 1
net 49.0002.2222.2222.2222.00
is-type level-2
metric-style wide
router-id lo0
exit
int gi0/0/0/1
point-to-point
exit
int gi0/0/0/0
point-to-point
exit
int lo0
prefix-sid index 2
exit
XRV3
segment-routing
mapping-server
prefix-sid-map
address-family ipv4
4.4.4.4/32 4
5.5.5.5/32 5
vrf vrf1
export route-target 3:3
import route-target 1:1
exit
int lo1
vrf vrf1
ip address 33.33.33.33 255.255.255.255
exit
router bgp 13
exit
exit
remote-as 13
update-source lo0
exit
neighbor 1.1.1.1
vrf vrf1
rd 3:3
network 33.33.33.33/32
exit
int gi0/0/0/0
ipv4 address 100.20.30.3 255.255.255.0
no sh
int lo0
ipv4 address 3.3.3.3 255.255.255.255
router isis 1
net 49.0003.3333.3333.3333.00
is-type level-2
metric-style wide
router-id lo0
exit
int gi0/0/0/0
point-to-point
exit
int lo0
prefix-sid index 3
exit
Sachin
Harold Ritter
Hi @sachin30720041 ,
You need to enable LDP on the interface towards CSR5 on XRV2.
mpls ldp
interface gi0/0/0/1
BTW, You do not need a mapping server in this scenario, since the PEs are both SR enabled. You only need a mapping server when a PE in the SR domain needs to talk to a PE in the LDP domain. Remove the mapping servers on XRV1 and XRV3 and do the VRF connectivity test between XRV1 and XRV3. It should work after doing the change recommended above.
Harold Ritter
mpls ldp
interface gi0/0/0/1
