ISDN dial to MPLS and HQ Problems...need help.
azmirccnp
I've a situation where I've two ISDN call backup using 1 BRI for my branch connection. First, the call will go to a nearest MPLS node, if this is failed, its will call to a second dialer string to my HQ. (there is 2 router at HQ, one connected to MPLS (3800), and second for ISDN and VOIP call(3640)).
The problem occur when everytime the ISDN call to MPLS, everything are OK. Then, when I disconnect the isdn dial to MPLS ( so it will call to HQ ), I can't access HQ.
If at first I call HQ and then MPLS, everything ok. But if I call back HQ after MPLS call, it can't route. From HQ 3800 router, I can see the route keep on searching at MPLS cloud and back to HQ router (looping).
At branch, the routing are to BRI1/0 :-
ip route 90.0.0.0 255.0.0.0 BRI1/0
ip route 80.0.0.0 255.0.0.0 BRI1/0
interface BRI1/0
ip unnumbered Loopback1
encapsulation ppp
dialer string 123456
dialer string 789011
dialer load-threshold 1 either
dialer-group 1
isdn switch-type basic-net3
isdn point-to-point-setup
ppp authentication chap callin
ppp chap hostname xxxxx
ppp chap password xxxxx
ppp multilink
ppp multilink load-threshold 1 either
end
**Both string configure at int BRI1/0, no int dialer used.
At HQ ISDN router i put this route :-
ip route 10.10.10.0 255.255.255.0 192.168.x.x 200
At HQ 3800 router i put :-
ip route 10.10.10.0 255.255.255.0 182.x.x.x 220
(182.x.x.x = MPLS node ip)
Need helps. Thanks.
jarvar832004
please check the foll
1. whether the bri interface ip in the branch1 router (loopback 1) has a proper reverse route in the MPLS cloud.
2. from the mpls pe connecting to the hq, pls chk the routing info for the destination to be reached.
hi jarvar,
I've already solve this problems. Its due to tracking time out problem. Thanks.
Azmir.
