Load-share IPsec traffic over MPLS
allalamine
I have an IPsec tunnel going through an MPLS VPN, between two CEs.
The IPsec destination is received over 4 links what means that I have 4 active paths to reach the tunnel destination (BGP multipath used)
Will the traffic be load shared over the 4 links ? or is it going to be forwarded over one selected path ? in last case, is there any way to load share it ?
Thanks all
lespejel
Level 3
Level 3
hello @allalamine
the short answer, it's not balanced.
Load balancing applies usually based on source and destination, sometimes you can add ports or something else to distribute the traffic, however because VPN peers will be sending same source destination packets, the CEF mechanism will always assign same path on one direction (it's same process in the other way).
there are mechanisms to distribute traffic, but I don't think it will apply to traffic between a single pair of CE's.
https://www.cisco.com/c/en/us/td/docs/switches/metro/me3600x_3800x/software/release/15-3_3_S/configuration/guide/3800x3600xscg/swmplsloadbalancing.pdf
CCIE 52804
lespejel
Level 3
Level 3
hello @allalamine
CCIE 52804
Many thanks @lespejel.
I think the only solution is to use IPsec in transport mode.
We'll expose the end hosts IPs, but that's not a high risk as in this scenario we're running IPsec on top of MPLS network.
you can also user multiple loopbacks for IPSec peers, then balancing will distribute among multiple paths using different source-dest. pairs.
Limitation here is, you cannot establish multiple GRE tunnels in the same VRF between 2 routers, it should use crypto maps or something alike, and then you have to split your traffic among several tunnels, which could happen with PBR and even consider QoS separation, it's a nice experiment to try.
CCIE 52804
