lsp path verification
maher
hi there,
just wondering, how to we determine that from PE to PE routers from the lsp path point of view? Any show command would be useful? I found that we could only verify using MPLS OAM..any other method perhaps..
thanks in advance.
maher
adityakaul
Maher,
U cld use Lsp ping/Trace if ur using 12.0(27)S and above.
I dont think any show cmd will show u the full lsp paths...apart from TE where in u know the path as u conf the ERO's }:
Junos can show u the Rsvp lsp path's if u add extensive.
Rgds
Aditya
