Maximum LSP on Inter-AS vpnv4/ipv4
fernando.romao
Hi Luc
Thank you for your reply, in fact we are in the process of using Option B (ASBR-to-ASBR). We have all the configs in place just did not activate the neighbors pending confirmation. We are using Eng5; I would expect CAM/TFIB to be able to hold these prefixes, I seem to have noticed that the weakest processor can handle up to one million. Yet, it is not written anywhere on these specifics.
FR
Luc De Ghein
Hi Fernando,
In MPLS VPN networks, 17000 vpnv4 prefixes is not that much. You can have hundreds of thousand of vpnv4 prefixes.
You did not specifiy which option A,B, C or D you are running. For option A and D, the scalability could become an issue because you'll have many logical links between the ASBRs, one for every VPN shared between the 2 autonomous systems. This is a known limitation factor in these two designs and it is a pain to operate such a model, starting from a certain scale. Each new VPN shared between the 2 autonomous systems will lead to the creation of a new logical link on the ASBRs.
Option B and C do not have this and are hence more scalable and easier to maintain operationally. What inter-as MPLS VPN brings is the concentration of the LSPs on the ASBRs, instead of having them spread over many PE and P routers in a non-inter-as MPLS VPN network. But, 17000 prefixes should be ok on a 12k router.
Luc
Luc De Ghein
Hi Fernando,
Luc
