QOS for Serial Interface in IOS-XR
kokulsharma
I am trying to configure QOS for a FR serial interface in IOS-XR.
But I don't see an option for configuring input/output service-policy in IOS-XR 3.9.1  for serial interface. These options are available for ethernet subinterfaces..
Following is the config:
class-map match-any QOS2
match dscp af21 af22 af23
match precedence 2
end-class-map
class-map match-any QOS3
match dscp af31 af32
match precedence 3
end-class-map
policy-map QOS_MAP
  class QOS3
  set dscp af21
class QOS2
  set dscp af21
class class-default
  set dscp default
end-policy-map
RP/0/8/CPU0:TEST-IOS-XR(config)#interface gigabitEthernet 0/1/0/4.1416
RP/0/8/CPU0:TEST-IOS-XR(config-subif)#service-policy ?
  input   configure a policy in the input direction
  output  direction of service policy application
  type    Enter service policy type (default: qos)
RP/0/8/CPU0:TEST-IOS-XR(config-subif)#exit
RP/0/8/CPU0:TEST-IOS-XR(config)#interface serial 0/0/1/0/1/1.500
RP/0/8/CPU0:TEST-IOS-XR(config-subif)#service-policy type ?
% Invalid input detected at '^' marker.
interface Serial0/0/1/0/1/1.500 point-to-point
cdp
vrf TEST
ipv4 address 10.10.10.1 255.255.255.252
pvc 500
Has anyone experienced this issue?
Mahesh Gohil
Level 7
Level 7
Hi Kokul,
You must be in pvc mode to configure service-policy on this interface
Mahesh
Mahesh Gohil
Level 7
Level 7
Hi Kokul,
Mahesh
Thanks Mahesh. It works..
I didn't check this option earlier..
Kokul
