Maximum VRF n VFI
jemekeren
hello there. what is the maximum VRF n VFI supported on cisco? what is the best selection for PE position? catalyst or Router? tq anyway... :)
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
Refer Link below for MPLS VPN and Multi-Virtual Route Forwarding Support for Cisco ISR:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6557/prod_white_paper0900aecd8051fbdc.html
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
mounir.mohamed
Level 7
Level 7
A lot of factors could effect your decision
-Number of links will be terminated on
-Amount of Traffic
-Number of customers will be terminated on the PE
-Services will be running on (AToM, TE..etc)
I recommend using Cisco 7200 Series in the PE position for small to mid-range ISP, large-scale ISP can use leadership series 7600.
Best Regards,
Mounir Mohamed
shivlu jain
Level 5
Level 5
