MPLS and GRE tunnel
kamlesh.sharma
Level 3
Level 3
Hi All,
I have lab configured like the diagram.my problem is when i configure a tunnel interface on ce1 with tunnel source interface s1/0 which is connected to PE1 and tunnel destination is the ip address of Ce2 which is connected to PE2.
OSPF is used for CE-PE connectivity and PE to PE it is running BGP.
error message which comes in the both router is tunnel interface going down because of recurcive lookup.
please help.
Kamlesh
This is the link for sham-links
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087ce2.html
But really your topology is suprising. What exactly are you trying to do ?
8 Replies 8
olorunloba
Level 5
Level 5
The most likely reason for a tunnel going down is recursive lookup. This happens when the route for the tunnel destination is via the tunnel itself.
Check
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094690.shtml
In your situation, I think OSPF adjacency is formed across the tunnel interfaces as well, when the tunnels comes up, and the address for CE2 is not learnt via the tunnel.
Try to change the mask in your OSPF configuration to ensure that the tunnel is not part of the ospf process. If it is a requirement, for OSPF to be formed across the tunnel interfaces, then you might want to use static host routes to ensure that the route for the tunnel destinations is never through the tunnel.
thanks for reply
But my question why it happens if bandwidth of the tunnel interface is less than serial interface than it should always prefer the serial interface not tunnel.
Thanks Kamlesh
It will be hard to answer the question without seeing your configuration. However, note that OSPF actually uses a cost for metric calculation. So while the bandwidth on the tunnel interface might be less than the serial, the cost associated with the prefix is not neccessarily so.
Let me try and explain further.
If the tunnel interface is configured for a bandwidth of 1Mb, then the OSPF cost will be 100/1 or 100. Since the tunnel is like a point to point link to CE2, then CE2 local prefixes will have a cost of 100 from the tunnel interface.
If serial interface is configured for 2Mb, then the cost is 100/2 or 50. This cost is added to the advertised one from the PE. If the PE advertises a cost of 100, then cost for prefixes from CE2 will now be 150. Therefore the prefixes from the tunnel will be preferred and entered into the routing table.
thanks again for your reply here i am posting my config according to your colculation it is possibe reason. but in my configuration ospf is in area 0 only and what i am thinking is when PE advertises the routing update to
PE device it comes as inter-area OIA whatever it is.
it my situation it is happening 55.55.55.5/32 route is coming as OIA in routing table but there i don't have any area other than backbone area 0. just have a look at the configuration and suggest me.
hostname RA
ip cef
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback1
ip address 202.41.3.1 255.255.255.252
interface FastEthernet0/0
ip address 11.11.11.1 255.255.255.0
interface Serial1/0
ip address 10.1.12.1 255.255.255.252
router ospf 100
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.1.12.0 0.0.0.255 area 0
network 11.11.11.0 0.0.0.255 area 0
hostname RB
ip cef
ip vrf vpan
description VPNA for customer A
ip vrf vpna
rd 1:100
route-target export 1:100
route-target import 1:100
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Serial1/0
ip vrf forwarding vpna
ip address 10.1.12.2 255.255.255.252
interface Serial1/1
ip address 10.1.23.2 255.255.255.0
mpls ip
router ospf 100 vrf vpna
redistribute bgp 1 metric 20 subnets
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
network 10.1.23.0 0.0.0.255 area 0
router bgp 1
bgp log-neighbor-changes
neighbor 4.4.4.4 remote-as 1
neighbor 4.4.4.4 update-source Loopback0
address-family ipv4
neighbor 4.4.4.4 activate
no auto-summary
no synchronization
exit-address-family
address-family vpnv4
neighbor 4.4.4.4 send-community extended
exit-address-family
address-family ipv4 vrf vpna
redistribute ospf 100 vrf vpna
no auto-summary
no synchronization
exit-address-family
address-family ipv4 vrf vpan
no auto-summary
no synchronization
exit-address-family
hostname RC
ip cef
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Loopback1
ip address 202.41.2.1 255.255.255.0
interface Serial1/0
ip address 10.1.34.3 255.255.255.0
mpls ip
interface Serial1/1
ip address 10.1.23.3 255.255.255.0
mpls ip
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
network 10.1.0.0 0.0.255.255 area 0
network 202.41.2.0 0.0.0.255 area 0
hostname RD
ip cef
ip vrf vpna
rd 1:100
interface Loopback0
ip address 4.4.4.4 255.255.255.255
interface Serial1/0
ip address 10.1.34.4 255.255.255.0
mpls ip
interface Serial1/1
ip address 10.1.45.4 255.255.255.0
network 10.1.45.0 0.0.0.255 area 0
router ospf 1
network 4.4.4.4 0.0.0.0 area 0
network 10.1.34.0 0.0.0.255 area 0
router bgp 1
neighbor 2.2.2.2 remote-as 1
neighbor 2.2.2.2 update-source Loopback0
address-family ipv4
neighbor 2.2.2.2 activate
no auto-summary
no synchronization
exit-address-family
neighbor 2.2.2.2 send-community extended
exit-address-family
no auto-summary
no synchronization
exit-address-family
hostname Re
ip cef
interface Loopback0
ip address 5.5.5.5 255.255.255.255
ip address 55.55.55.5 255.255.255.0
interface Serial1/1
ip address 10.1.45.5 255.255.255.0
router ospf 100
network 5.5.5.5 0.0.0.0 area 0
network 55.55.55.0 0.0.0.255 area 0
Seeing the route as an O IA is normal behaviour as in MPLS-VPN the MPLS core will act as a super backbone and hence O routes in one PE will appear as O IA after it crosses the MPLS backbone. To override this behaviour, configure OSPF sham-links between the PEs which will retain the routes as the O routes. I think in this case the tunnel is acting as a backdoor link and hence it learns the prefixes as O routes instead of the O IA from the Serial. Configure sham-links and i think it will work fine.
Hi Gautam,
Thanks for your reply.
It's true in my topology route are coming OIA from physical interface and and O from tunnel interface. so i think your suggestion will be great to solve thins problem.
could you please give me the configuration according to my setup given above.
kamlesh
Hi Gautam,
Link is very usefull. about my topology it is just for study purpose nothing else.
