MPLS / BGP Inter AS route exchage
Istvan kelemen
Hi everyone,
I am trying to build a real life topology. My goal is to exchange private routes between 2 MPLS provider via the public internet without leaking the private routes to public internet. So the router in the top right corner should be able to ping the router below and ISP routers should not know about private routes.
The interfaces of ATnT_PE_PE and SWC_PE_PE toward to ISP are in VRF INET. I estabilished a BGP ipv4 VRF INET session between two MPLS providers, the connectivity is fine however when i filter the private routes on ISP this movement brakes the connectivity.
How can i get it working?
I will post the configs of two Service provider EDGE routers:
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf INET
rd 100:100
route-target export 100:100
route-target import 100:100
route-target import 1:1
ip vrf OCH
rd 1:1
route-target export 1:1
archive
log config
  hidekeys
interface Loopback0
ip address 10.1.1.1 255.255.255.255
interface Tunnel0
no ip address
tunnel source Serial1/0
tunnel destination 20.0.0.1
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip vrf forwarding INET
ip address 40.0.0.2 255.255.255.252
ip nat outside
ip virtual-reassembly
serial restart-delay 0
interface Serial1/1
ip address 10.0.0.1 255.255.255.252
ip nat inside
mpls ip
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.1 0.0.0.0 area 0
network 10.1.1.1 0.0.0.0 area 0
router bgp 200
bgp router-id 40.0.0.2
bgp log-neighbor-changes
neighbor 10.3.3.3 remote-as 200
neighbor 10.3.3.3 update-source Loopback0
address-family ipv4
  neighbor 10.3.3.3 activate
  no auto-summary
  no synchronization
exit-address-family
address-family vpnv4
  neighbor 10.3.3.3 send-community both
exit-address-family
address-family ipv4 vrf OCH
  no synchronization
exit-address-family
address-family ipv4 vrf INET
  neighbor 20.0.0.1 remote-as 100
  neighbor 20.0.0.1 ebgp-multihop 10
  neighbor 20.0.0.1 activate
  neighbor 20.0.0.1 send-community both
  neighbor 40.0.0.1 remote-as 1
  neighbor 40.0.0.1 activate
  no synchronization
  network 40.0.0.0 mask 255.255.255.252
exit-address-family
ip forward-protocol nd
ip http server
no ip http secure-server
access-list 10 permit 10.0.0.0 0.255.255.255
access-list 10 permit 172.16.0.0 0.0.255.255
access-list 10 permit 172.17.0.0 0.0.255.255
access-list 10 permit 172.18.0.0 0.0.255.255
access-list 10 permit 172.19.0.0 0.0.255.255
access-list 10 permit 172.20.0.0 0.0.255.255
access-list 10 permit 172.21.0.0 0.0.255.255
access-list 10 permit 172.22.0.0 0.0.255.255
access-list 10 permit 172.23.0.0 0.0.255.255
access-list 10 permit 172.24.0.0 0.0.255.255
access-list 10 permit 172.25.0.0 0.0.255.255
access-list 10 permit 172.26.0.0 0.0.255.255
access-list 10 permit 172.27.0.0 0.0.255.255
access-list 10 permit 172.28.0.0 0.0.255.255
access-list 10 permit 172.29.0.0 0.0.255.255
access-list 10 permit 172.30.0.0 0.0.255.255
access-list 10 permit 172.31.0.0 0.0.255.255
access-list 10 permit 192.168.0.0 0.0.255.255
access-list 10 permit any
mpls ldp router-id Loopback0
control-plane
line con 0
line aux 0
line vty 0 4
login
end
version 12.4
hostname ATnT_PE_PE
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip vrf INET
rd 100:100
ip vrf OCH
rd 1:1
no ip domain lookup
archive
log config
  hidekeys
ip tcp synwait-time 5
interface Loopback0
ip address 10.4.4.4 255.255.255.255
interface Tunnel0
no ip address
tunnel source Serial1/2
tunnel destination 40.0.0.2
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 10.0.14.4 255.255.255.0
ip router isis
ip nat inside
mpls ip
interface Serial1/1
no ip address
shutdown
interface Serial1/2
ip address 20.0.0.1 255.255.255.252
ip nat outside
interface Serial1/3
no ip address
shutdown
router isis
net 00.0000.0000.0004.00
passive-interface Loopback0
router bgp 100
neighbor 10.3.3.3 remote-as 100
neighbor 10.11.11.11 remote-as 100
neighbor 10.11.11.11 update-source Loopback0
neighbor 10.22.22.22 remote-as 100
neighbor 10.22.22.22 update-source Loopback0
address-family ipv4
  neighbor 10.11.11.11 activate
  neighbor 10.22.22.22 activate
  no auto-summary
  no synchronization
exit-address-family
  neighbor 10.3.3.3 route-reflector-client
  neighbor 10.11.11.11 send-community both
  neighbor 10.11.11.11 route-reflector-client
  neighbor 10.22.22.22 send-community both
  neighbor 10.22.22.22 route-reflector-client
exit-address-family
  no synchronization
exit-address-family
  neighbor 20.0.0.2 remote-as 1
  neighbor 20.0.0.2 activate
  neighbor 40.0.0.2 remote-as 200
  neighbor 40.0.0.2 ebgp-multihop 10
  neighbor 40.0.0.2 activate
  neighbor 40.0.0.2 send-community both
  no synchronization
  network 20.0.0.0 mask 255.255.255.252
exit-address-family
no ip http server
route-map FILTER deny 10
match ip address 10
route-map FILTER permit 20
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
blau grana
Level 7
Level 7
Hi Istvan,
I see that ISP RED and ISP PURPLE are using different AS numbers, are they two different ISPs or are they the one ISP divided by public internet in your scenario?
If they are two different ISPs, you should consider using one of Inter-AS MPLS VPN solution.
If they are one ISP, why don't you use same AS number?
Also, lets say that green area is the third ISP, a big one. I would purchase Layer2 link between both edge routers in RED and PURPLE area.
It is hard to help you aby further, because you did not provide enough information.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
I the ISPs are 2 different ones in the green area. I will implement either a l2 VPN solution or CSC (B2B VRF or so on).
Thanks anyway!
Hi Istvan
Looking at your design, it looks like you are trying to have a LAN based connectivity between sites since you have installed switches. L2VPN based solution like EoMPLS or VPLS would be a good option. If the Switches are acting as L3 devices then you can go for CSC.
--Vinit
