MPLS configuration issue on 2621XM (IOS 12.4)
Tasawurshaheen
Hello Experts,
I have a cisco 2621xM (IOS 12.4) router and I am trying to use this router as PE in MPLS environment (L3 MPLS VPN), not able to configure it for MPLS commands, not sure whether this router supports MPLS or IOS is the issue.
Background on device: This router is a device under test and I have testing tools that creates/emulates MPLS L3VPN type of environment with bunch of PEs, Ps, and CEs. This device is being tested but not able to configure it for MPLS. Any assistance would help.
Tas
Raju Sekharan
What is the exact image name you are using?
You need services image like advipservices to have MPLS support
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin09186a00801af451.html
Raju
I am using the image below, could you please advise which IOS should i be using ? and where i can find it ? and method to uplaod a new IOS without messing up the configs ? Thanks
Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(25d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 18-Aug-10 04:49 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
c2621XM uptime is 3 hours, 27 minutes
System image file is "flash:c2600-adventerprisek9-mz.124-25d.bin"
Cisco 2621XM (MPC860P) processor (revision 4.1) with 127308K/3764K bytes of memory.
Processor board ID FTX0916A17K
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Try using
c2600-advipservicesk9-mz.124-25d
Raju
