TE FRR Autotunnel Failover Times
gabbdavida
I'm trying to use the Cisco Auto tunnel Traffic Engineering feature to improve convergence times; with FRR, these still appear to be of the order of 1 second not the sub second fail-over I was expecting to see. With a standard Windows ping, one or two polls are always lost and CCTV traffic picture sync is lost on each occasion. The NHOP/NNHOP backup tunnels appear to work correctly; fails over to NNHOP.
The network is a mix of ME3600 (PE) and C6509 (P) providing L3VPN services.
config extract below:
mpls traffic-eng tunnels
mpls traffic-eng auto-tunnel backup
mpls traffic-eng auto-tunnel backup config unnumbered-interface Loopback0
mpls traffic-eng auto-tunnel backup tunnel-num min 1000 max 1200
mpls ldp explicit-null
mpls label protocol ldp
interface Tunnel3
ip unnumbered Loopback0
tunnel destination 10.172.2.9
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 128
tunnel mpls traffic-eng path-option 1 explicit name tpi_main
tunnel mpls traffic-eng fast-reroute
ip explicit-path name tpi_main enable
next-address 10.172.2.1
next-address 10.172.2.2
shreerampardhy
Hello Gabbdavida,
The backup tunnels usually kick-in once the failure has been detected. What mechanism are you using for detection of failure? Do you have BFD or Loop free alternate ( for OSPF ) enabled? Bfd can give you faster detection timers in order of milliseconds.
Shreeram
