MPLS IPv6 Inter VRF Problem
gilanx2010
Community Member
We have a case MPLS 6PE configuration as below, we can't ping inter vrf in local router from the gateway, but i can ping & browsing from my PC/router behind PE using gateway vrf Test-IPv6, any solution regarding this issue ? Has anyone ever encountered this problem ?  Thanks.
#ping vrf Test-IPv6 ipv6 2404:8000:1745:1::CA
Sending 5, 100-byte ICMP Echos to 2404:8000:1745:1::CA, timeout is 2 seconds:
Success rate is 0 percent (0/5)
#ping vrf Test-IPv6 ipv6 2404:8000:1745:1::C9
Sending 5, 100-byte ICMP Echos to 2404:8000:1745:1::C9, timeout is 2 seconds:
vrf definition Internet
rd 17451:10003
address-family ipv4
route-target export 17451:10003
route-target import 17451:412
exit-address-family
address-family ipv6
exit-address-family
vrf definition Test-IPv6
rd 17451:412
address-family ipv4
exit-address-family
address-family ipv6
route-target export 17451:412
route-target import 17451:10003
exit-address-family
interface GigabitEthernet1/26
vrf forwarding Test-IPv6
no ip address
ipv6 address 2404:8000:90:2::1/64
ipv6 enable
interface Port-channel2
description **** to Internet***
vrf forwarding Internet
mtu 9000
ipv6 address 2404:8000:1745:1::CA/126
ipv6 enable
router bgp 17451
address-family ipv4
  no synchronization
  no neighbor xxx.xxx.xxx.xxx activate
  no auto-summary
exit-address-family
address-family vpnv4
  bgp scan-time 10
  neighbor xxx.xxx.xxx.xxx send-community extended
  neighbor xxx.xxx.xxx.xxx advertisement-interval 10
exit-address-family
address-family ipv6
  no synchronization
exit-address-family
address-family vpnv6                                               ---->    to RR-Router
exit-address-family
address-family ipv6 vrf Internet
  redistribute connected
  redistribute static
  default-information originate
  no synchronization
exit-address-family
address-family ipv6 vrf Test-IPv6
  no synchronization
exit-address-family
soporte.sona
Frequent Visitor
Frequent Visitor
Did you solve this problem?
It is not possible to ping addresses in one vrf using the other vrf as a source on the local router. This does not prevent hosts in one vrf to ping hosts in the other vrf.
