MPLS-TP
helipos00
Just a quick one, if any is able to post up some MPLS-TP configs off a working system that would be greatly appreciated.
I'm trying to setup MPLS-TP on some ASR920 and not having much luck.
Cheers
helipos00
Never mind, I got it working.
If anyone is curious the config is attached.
Dear helipos00,
Thanks for information ,
Can you share logical diagram and configuration for the task you performed , as we are in the design stage of our project including
1) Our Ring include 2 cpt-600 as (master and slave) plus 4 cpt-50 in the same ring now we need to configure mid point and end point tunnel
configuration .
2) Service instance configuration
your prompt reply will be highly appreciated.
Best Regards
