mpls is not coming up...
Muhammed AKYUZ
hi
ON ASR 9000
i want to enable mpls but i am not able to enable it:
RP/0/0/CPU0:R9#
RP/0/0/CPU0:R9#
RP/0/0/CPU0:R9#conf t
Mon Oct  1 10:29:44.666 UTC
RP/0/0/CPU0:R9(config)#mpls ?
  ip-ttl-propagate  Propagate IP TTL into the label stack
  label             Label properties
Mohammed Imran Khan
Hello Muhammed,
This seems to be the licensing issue.
Do you see mpls pie in "show inst summary" in admin mode?
(admin)#show inst summ
If you are unable to see the mpls within the active packages in the above output, you will not be able to configure any mpls features. Please download the tar file from cisco.com and then unzip and install it.
This should resolve your issue.
Imran
