MPLS L3VPN connectivity issue between CEs
bassomarco1998
Hi all,
I configured the following lab to understand how the L3VPN service works. I set up everything except MPLS within AS 2. In the CE routers, I configured 2 loopbacks (R1: 1.1.1.1/32 and R4: 4.4.4.4/32) and advertised them via BGP. I then created a VRF "VRFA" on both routers and assigned the PE interfaces connected to the CEs to that VRF.
However, if I try to ping from loopback 1.1.1.1 to loopback 4.4.4.4, it doesn't work. This is because the VRF's routing table doesn't contain the subnet of the R2-R3 connection. How can this problem be resolved? Is it mandatory to use MPLS for this case?
Here ere are the R2's RIB (global and VRF).
R2#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
      192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.0.0/24 is directly connected, Ethernet0/1
L        192.168.0.2/32 is directly connected, Ethernet0/1
R2#sh ip route vrf VRFA
Routing Table: VRFA
      1.0.0.0/32 is subnetted, 1 subnets
B        1.1.1.1 [20/0] via 10.0.0.1, 00:21:01
      2.0.0.0/32 is subnetted, 1 subnets
C        2.2.2.2 is directly connected, Loopback1
      3.0.0.0/32 is subnetted, 1 subnets
B        3.3.3.3 [200/0] via 192.168.0.3, 00:21:01
      4.0.0.0/32 is subnetted, 1 subnets
B        4.4.4.4 [200/0] via 192.168.0.3, 00:13:15
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.0.0.0/24 is directly connected, Ethernet0/0
L        10.0.0.2/32 is directly connected, Ethernet0/0
 Thanks!
22 Replies 22
MPLS table and RIB table
Is the RIB table you are referring to the global one?
RIB VRF
But Harold said that the router will use the Global RIB, not the custom VRF
The RIB global job end when mpls table build it not use any more. That why mpls is mandatory' your original topolgy config vpnv4 without mpls it will not work even if next-hop is in global RIB. It need mpls table.
That what I know.
MHM
Hi @bassomarco1998 ,
Two things here:
1. lookup for packets coming from R1 will be performed in the VRF RIB (or more specifically VRF FIB).
2. Routes received from VPNv4 will be installed in the VRF RIB and the next hop resolution for these routes will be via the global routing table and have to be via an MPLS enabled path.
Harold Ritter
Yes, you need to run MPLS between R2 and R3 to provide L3VPN services to R1 and R4.
BTW, it would be preferable to configure a loopback interface on both R2 and R3, advertise in the IGP between R2 and R3 and use the loopback to configure the VPNv4 session between these two routers.
Thank you, @Harold Ritter , for your response.
However, there's something that isn't clear to me. Let's assume I've configured VPNv4 peering between the loopbacks of R2 and R3.
When I perform the ping (src: 1.1.1.1, dst: 4.4.4.4), the ICMP packets arrive on interface e0/0 of R2. At this point, R2 consults the RIB related to VRF 'VRFA'. However, the next hop appears to be the loopback of R3, which isn't part of the VRFA. So, my question is: why should the R1-R4 connectivity work when I configure MPLS? Wouldn't the RIB of VRFA on R2 remain unchanged?"
The next hop resolution for VPNv4 routes take place in the global routing table and the routes are then imported in the VRF.
