MPLS lab test
william2u
hi guyz, i got three 2500 router with MPLS support, and a 2621 with Telco feature IOS. One 3620.....
4 routers can play MPLS & BGP / VPN ??
mheusinger
Level 10
Level 10
yes this is possible. F.e. CE1(3620) - PE1(2500MPLS) - PE2(2500MPLS) - CE2
In case you have Serial interfaces use Frame Relay with different, separate PVCs and you can also setup "redundancy" and the like.
If your 3620 and 2621 IOS supports tag-switching you could use them as PE routers. There is no need for a "P" router to test MPLS VPN.
Hope this helps! Please rate all posts.
Regards, Martin
