VPLS lab test ?
william2u
Level 3
Level 3
hi guys, i plan to test for VPLS ... wat device i need. i got 2950c, 2600, 2500, 3600.
mheusinger
Level 11
Level 11
officially you will need Cisco 7600 or 12000 to setup VPLS. VPLS is not supported on the equipment you mentioned. You can only use it as CE devices.
Regards, Martin
mithil_r
Level 2
Level 2
What do u want to test exactly??? A PE or an MTU???
Would be thankful if u have some test plan....
MITHIL
i wan2 test PE
