MPLS LDP FLAPPING CONTINUOUSLY
rawat.umed
We are facing issue of ldp flapping continously in our mpls network.
3: Jan  9 12:47:12 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (0) is DOWN (Received error notification from peer: KeepAlive expired)
1046264: Jan  9 12:47:13 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): starting graceful recovery
1046265: Jan  9 12:47:13 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (34) is UP
1046266: Jan  9 12:47:58 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): completed graceful recovery
1046267: Jan  9 12:49:13 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): completed graceful recovery
1046268: Jan  9 12:50:08 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): interrupted--recovery pending
1046269: Jan  9 12:50:08 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (0) is DOWN (Session KeepAlive Timer expired)
1046270: Jan  9 12:50:09 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): starting graceful recovery
1046271: Jan  9 12:50:09 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (9) is UP
1046272: Jan  9 12:51:23 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): interrupted--recovery pending
1046273: Jan  9 12:51:23 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (0) is DOWN (Received error notification from peer: KeepAlive expired)
1046274: Jan  9 12:51:26 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): starting graceful recovery
1046275: Jan  9 12:51:26 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (38) is UP
1046276: Jan  9 12:51:26 IST: %OSPF-5-ADJCHG: Process 1, Nbr 10.134.254.2 on GigabitEthernet1/8 from FULL to DOWN, Neighbor Down: BFD node down
1046277: Jan  9 12:51:29 IST: %OSPF-5-ADJCHG: Process 1, Nbr 10.134.254.2 on GigabitEthernet1/8 from LOADING to FULL, Loading Done
1046278: Jan  9 12:52:09 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): completed graceful recovery
1046279: Jan  9 12:53:26 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): completed graceful recovery
1046280: Jan  9 12:54:19 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): interrupted--recovery pending
1046281: Jan  9 12:54:19 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (0) is DOWN (Session KeepAlive Timer expired)
1046282: Jan  9 12:54:22 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): starting graceful recovery
1046283: Jan  9 12:54:22 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (11) is UP
1046284: Jan  9 12:55:36 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): interrupted--recovery pending
1046285: Jan  9 12:55:36 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (0) is DOWN (Received error notification from peer: KeepAlive expired)
1046286: Jan  9 12:55:37 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): starting graceful recovery
1046287: Jan  9 12:55:37 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (34) is UP
1046288: Jan  9 12:56:18 IST: %OSPF-5-ADJCHG: Process 1, Nbr 10.134.254.2 on GigabitEthernet1/8 from FULL to DOWN, Neighbor Down: BFD node down
1046289: Jan  9 12:56:22 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): completed graceful recovery
1046290: Jan  9 12:56:24 IST: %OSPF-5-ADJCHG: Process 1, Nbr 10.134.254.2 on GigabitEthernet1/8 from LOADING to FULL, Loading Done
1046291: Jan  9 12:57:37 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): completed graceful recovery
1046292: Jan  9 12:58:32 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): interrupted--recovery pending
1046293: Jan  9 12:58:32 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (0) is DOWN (Session KeepAlive Timer expired)
1046294: Jan  9 12:58:33 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): starting graceful recovery
1046295: Jan  9 12:58:33 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (9) is UP
1046296: Jan  9 12:59:47 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 34): interrupted--recovery pending
1046297: Jan  9 12:59:47 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (0) is DOWN (Received error notification from peer: KeepAlive expired)
1046298: Jan  9 12:59:47 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): starting graceful recovery
1046299: Jan  9 12:59:47 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (38) is UP
1046300: Jan  9 13:00:33 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): completed graceful recovery
1046301: Jan  9 13:01:47 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): completed graceful recovery
1046302: Jan  9 13:02:43 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 9): interrupted--recovery pending
1046303: Jan  9 13:02:43 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (0) is DOWN (Session KeepAlive Timer expired)
1046304: Jan  9 13:02:44 IST: %LDP-5-GR: GR session 10.135.254.27:0 (inst. 11): starting graceful recovery
1046305: Jan  9 13:02:44 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.27:0 (11) is UP
1046306: Jan  9 13:03:57 IST: %LDP-5-GR: GR session 10.135.254.21:0 (inst. 38): interrupted--recovery pending
1046307: Jan  9 13:03:57 IST: %LDP-5-NBRCHG: LDP Neighbor 10.135.254.21:0 (0) is DOWN (Received error notification from peer: KeepAlive expired)
We have checked the interfaces and no flapping were there in that.
Also when we gave the cmd
SUR_COR#sh mpls ldp nei 10.135.254.27
    Peer LDP Ident: 10.135.254.27:0; Local LDP Ident 10.135.254.2:0
        TCP connection: 10.135.254.27.37737 - 10.135.254.2.646
        State: Oper; Msgs sent/rcvd: 2276/2; Downstream
        Up time: 00:00:08
        LDP discovery sources:
          Targeted Hello 10.135.254.2 -> 10.135.254.27, active, passive
no ip are there in targeted hello .
while at the other end
SUR_PE1#sh mpls ldp nei 10.135.254.2
    Peer LDP Ident: 10.135.254.2:0; Local LDP Ident 10.135.254.27:0
        TCP connection: 10.135.254.2.646 - 10.135.254.27.37737
        State: Oper; Msgs sent/rcvd: 2277/2278; Downstream
        Up time: 00:02:00
          Targeted Hello 10.135.254.27 -> 10.135.254.2, active, passive
        Addresses bound to peer LDP Ident:
          10.135.254.2    10.135.7.233    10.135.7.249    10.135.7.229
          10.135.7.237    10.135.7.217    10.135.7.213    10.135.7.201
          10.135.7.6      10.135.7.225    10.135.7.197    10.134.1.26
          10.135.7.10     10.135.7.26     10.134.1.50     10.135.7.221
          10.135.7.193    10.135.7.245    172.18.123.145  172.18.123.221
          10.134.1.34     10.135.7.241    10.135.7.177    10.134.1.30
          10.135.7.205    10.135.7.209    10.135.7.14     10.135.7.17
          10.135.7.21
we are getting intermediate ip addresses.
Any one can help regarding this
Rivalino Tamaela
From show command we can see that SUR_COR receives less LDP messages, could be dropped along the path. It sent 2276 but receives only 2 packets from its neighbor.
        Up time: 00:00:08
While SUR_PE1 could send and receive LDP messages correctly. Need to investigate if there is any congestion one way from 10.135.254.2 to 10.135.254.27.
HTH,
Rivalino
Ashish Panda
Hi Umed,
Folwing are some suggestions
- Try to check match LDP configuration if you have changed LDP timers
- Try to check the negotiated MTU for the TCP session is supported on the path
- Check for possible packet drops in the path
- Check if you have any performance issue (high CPU etc) on any end routers
regards
Ashish
