MPLS on Cisco 2600 ???
klein.herve
I want to know if it is possible to use MPLS on CISCO 2600 routers and if it is possibe with witch IOS reference. We try to do this in our case study nd we encounter difficulies to find reliable infrmations.
mheusinger
Level 10
Level 10
according to the Feature Navigator (had a quick look only) MPLS is supported in 2610/2611XM at least since 12.3. I would recommend Enterprise Plus or SP Services feature set.
Be aware however that not every feature available in 7200 and above will be available for the 2600
Hope this helps! Please rate all posts.
Regards, Martin
AJAZ NAWAZ
Level 5
Level 5
Klein,
Please take a read of the following url:
<http://www.netcraftsmen.net/welcher/papers/mpls2.html>
"By the way, if you're wondering about what equipment to try this on, it looks as if 12.1(3) T supports MPLS in 2600 routers (although the feature matrix doesn't show this). So MPLS over IP should be fairly do-able, equipment-wise. "
Getting hold of this image/IOS will be your next hurdle ;)
all the best
Ajaz Nawaz
