01-28-2012 09:30 AM
Dear All,
I have MPLS network, the routers are being used cisco ASR9000 you are planning to build a backup link between these router, the existing link sis fiber link,
The satellite modem has serial interface V.35, we are using cisco router(2921) with smart serial (Hwic) to connect it, this router is necessary needed to bring the satellite link up, the initial communication between the router and the modem the is V.25bis to trigger the modem and initiate a link between the other modem at the other end after the satellite link established , the router build PPP link between the other end.
This is the configuration on 2921
interface FastEthernet0/0
ip address 192.168.11.99 255.255.255.0
duplex auto
speed auto
1nterface serial0/0
ip address 10.10.100.2 255.255.255.0
encapsulation ppp
ip tcp header-compression iphc-format
no ip mroute-cache
dialer in-band
dialer idle-timeout 30
dialer wait-for-carrier-time 30
dialer map ip 192.168.10.101 name HUB_ HSCU_ 1 101
dialer map ip 192.168.10.102 name HUB_ HSCU_ 2 101
dia1er·group 1
fair -Queue 64 256 36
pulse-time 2
IP rtp header-compression iphc-format
ip classless
ip route 192.168.10.0 255.255.255.0 ser1a10/0
no ip http server
Since we are using MPLS which is layer 2.5, the 2921 will modify the whole packet and rebuild it and lose the MPLS information 24 bytes then we will the connectivity between the MPLS routers.
My question is there a way to solve the puzzle
Solved! Go to Solution.
02-21-2012 01:34 AM
Abdallah,
Those IOS versions are first IOS versions in which this command was implemented or modified. From those versions and going forward, the command should be available in all newer IOS versions.
What IOS Feature Set or license are you running? It is possible that you need additional license to unlock the necessary functionality.
Best regards,
Peter
02-21-2012 03:47 AM
Hi Abdallah,
You'll need 'data' license to use this feature.
You can try to evaluate this license to test your configuration (if not evaluated before):
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155619
Sergey
01-28-2012 01:53 PM
You can build L2TPv3 tunnel between 2921 over satellite link and xconnect ethernet interfaces facing MPLS routers.
Check this thread:
01-29-2012 01:48 AM
Thanks Sergey
My understand about L2TP is supporting Point to point session and not supporting point-to-multipoint or multipoint-to-point sessions.
My situation is point to multipoint; Hub with 6 remotes , but on the other hand the technology we are using on satellite allow only on link between the hub and one of the remote on other word we can’t establish to more than one connection in one time, we using technology named DAMA (demand assigned multiple access )to save bandwidth on satellite you only assign the 2 Mb only for one remote at a time based on demand .
Attached draw for the current setup,
Any suggestions help
01-30-2012 11:22 PM
Any suggestions ??
02-02-2012 06:01 AM
As I see there should be 2 ways:
- build l2tp tunnels between your hub and remote sites (terminate in different vlans on your hub)
one of the tunnel will come up and you'll get l2 connectivity between hub and remote site, while 2921 will remain transparent to the network
- As I see in docs 2921 supports MPLS and you should be able to configure it over PPP interface
02-04-2012 06:28 AM
As sergey suggested, you can run L2TPv3 PW between the 2921 in a hub and spoke manner but in a point to point fashion.
and you can run PPPoL2TPv3. you dont need to run MPLS as L2TPv3 supports PPP,HDLC,ATM,Ethernet, frame relay etc
Kishore
02-08-2012 08:58 AM
Thanks Kishore and sergey,
My question is how can I determine the destinations for MPLS traffic coming to my 2921router on fast Ethernet port? I have different destination and according the above configurations I need to know which site should traffic goes then dial up the interface as command does
By the way there are VLAN tags with MPLS traffic coming to my port
02-08-2012 03:47 PM
For example you have Fa0/0 facing your mpls router, then you have 3 sub-interfaces:
pseudowire-class pwc_l2tp
encapsulation l2tpv3
ip local interface Loopback0
int Fa0/0
no ip address
mtu ...
int Fa0/0.10
encapsulation dot1q 10
xconect [remote_ip_10] 10 pw-class pwc_l2tp
int Fa0/0.11
encapsulation dot1q 11
xconect [remote_ip_11] 11 pw-class pwc_l2tp
int Fa0/0.12
encapsulation dot1q 12
xconect [remote_ip_12] 12 pw-class pwc_l2tp
You should have routes to remote_ip_xx which are remote loopback ip addresses.
You can then use this remote_ip_xx in your dialer map. L2TPv3 traffic will trigger your dialer...
02-20-2012 03:38 AM
One more thing i am trying to configure 2921 but i found it dosent support
pseudowire-class command i am trying to look for suitable IOS, can guid me for the right one?
02-21-2012 01:02 AM
Something strange i tried many of IOS nothing helped, the IOSs released for 2900 starting 15.0 and link below
http://www.cisco.com/en/US/docs/ios/wan/command/reference/wan_m1.html#wp1013715
states that the supported IOSs are 12.0(23)S , 12.3(2)T , 12.2(25)S and 12.2(27)SBC.
Where can I find such IOS release.
02-21-2012 01:34 AM
Abdallah,
Best regards,
Peter
02-21-2012 02:04 AM
Hi Peter,
I tried these IOS:
c2900-universalk9-mz.SPA.151-1.T
c2900-universalk9-mz.SPA.151-2.GC1
c2900-universalk9-mz.SPA.150-1.M7
with show version command shows that I have only IP base no security or Voice license,
what do you think I need to be able to run this command?, on other hand while I am suing GNS3 I able to run the command on 3725 with c3725-adventerprisek9-mz.124-15.T10.bin IOS.
Abdallah
02-21-2012 03:47 AM
Hi Abdallah,
Sergey
04-14-2012 09:53 AM
I have implemented this configuration on the VSAT routers
When i checked the L2TPv3 configuration, show l2tun session all
Shows me everything is fine and the tunnel established
Before I bring the MPLS traffic, is there way to check the if L2TPv3 configuration fine? Like using laptop to ping the other side
Abdallah
05-26-2012 07:31 AM
HI Sergey
Actually the L2TPv3 always attempts to build the tunnel between the two routers, regardless if the customer send data or not, the point is WAN should go up only if there is traffic coming from the customers (MPLS)routers , since the satellite is backup link and are charged based on the usage.
Is there way to build access list based on the traffic coming from customer side?
The Traffic has VLAN tag based on the VLAN tag, the L2TPv3 Build the tunnel for specific destination?
