MPLS Simulator
lovefunlove
Hi Friends,
Can anyone of you pls tell me a software tool for MPLS Simulator.....?
MAX
5 Replies 5
longene.leonard
Max,
The answer to this question depends on your budget. If you are interested in a powerful toolset for MPLS Simulation, send me an email to discuss a solution I'm evaluating at the moment. Its not cheap! But quality never is..
longene.leonard@charter.net
emaamur2006
Hi Max
Have a look at this, its a 7200 simulator, i have used it for MPLS labs with no issues except you will have to get the right image. let me know if you need anymore help. Also, do a search on these forums, there is quite alot postings about it
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
BR
emaamur
LonGene Leonard
LonGene Leonard
LonGene Leonard
LonGene Leonard
Alex M
Whay can't you use GNS3?
