MPLS TE Admission control
Mehdidz
Hi Folks,
I'm pretty new to the MPLS TE topic, and I've a question for which I can't find an answer on my readings
let's  assume that we have the topology in the attached diagram
IS-IS is used as the IGP; with MP-BGP for VPN traffic, PE to CE is eBGP
Every link is a 10 Mbps link of which 6 Mbps are used by TE,
every node has a master tunnel which has   a default tunnel and an LLQ tunnel
the TE metric has been left by the default (equal to the IGP metric)
every single  node has tunnel to all other nodes (full mesh tunnels)
all tunnel interfaces have the config bellow
interface Tunnel10
 description Tu RX (Master)
 bandwidth 10000
 ip unnumbered Loopback0
 tunnel mode mpls traffic-eng
 tunnel destination 169.254.1.2
 tunnel mpls traffic-eng autoroute announce
 tunnel mpls traffic-eng exp-bundle master
 tunnel mpls traffic-eng exp-bundle member Tunnel11
 tunnel mpls traffic-eng exp-bundle member Tunnel12
interface Tunnel11
 description Tu Rx (Default)
 bandwidth 6000
 load-interval 60
 tunnel mpls traffic-eng priority 7 7
 tunnel mpls traffic-eng bandwidth 4000
 tunnel mpls traffic-eng path-option 10 dynamic
 tunnel mpls traffic-eng record-route
 tunnel mpls traffic-eng fast-reroute
 tunnel mpls traffic-eng auto-bw frequency 300 adjustment-threshold 5 max-bw 4000 min-bw 1000
 tunnel mpls traffic-eng exp default
interface Tunnel12
 description Tu RX (LLQ)
 bandwidth 4000
 tunnel mpls traffic-eng bandwidth sub-pool 2000
 tunnel mpls traffic-eng exp 5
My Questions are
1-     Having the default  MPLS TE metric equal to the IGP metric , and assuming that the path going to R9 through R8 is always the best path from an IGP point of view
the LSP being used to get from R1 to R9 is R1-R8-R9 and  all reservable bandwidth has been used (6 Mbps) , so we have 4 Mbps left on R8-R9
R2-R8-R9 is the best path (best Metric IGP/TE)
When RSVP signals the LSP to go to from R2 to R9 is the LSP going to be built using a less preferred path in terms of metric or will this result in and admission control failure?
2-     Is the sub-pool bandwidth dedicated from  the master tunnel interface or the Tunnel 12 ?
Many thanks in advance for your help
Kind regards
Mehdi
3 Accepted Solutions
mcusine
Hi Mehdi,
I am not sure if I undestood your question. But when you use MPLS TE with RSVP you can choice but path will follow to create the LSP, static or dynamic in you example you choice dynamic (follow the IGP metric path).
Now when the LSP try to make it the path followed goes trought the igp path, now RSPV will try to stablish the LSP with the bandwidth that you define.
Figure 1. RSVP Operation.
If the path have enought bandwidth the LSP will stablish and tunnel go up, but remember that is only admi reservation if you reserve 4MB and send 10MB of traffic the traffic will pass this is not a bandwidth guarantee.
I attach some interested links, one for concept and configuration :
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/mpls/configuration/guide/b_mpls_cg43xasr9k/b_mpls_cg43asr9k_chapter_010.html#con_1130655
And another from the support community.
https://supportforums.cisco.com/discussion/9784116/mpls-te-tunnel-bandwidth-and-ip-rsvp-bandwidth
I don't know this help you but I tried.
Mauricio
Hi Mehdi,
I think yes, because when RSVP send the path message he send over all posible paths, in this case the best path not enought bandwidth and suboptimal path yes, the LSP will créate over the suboptimal path.
King regards,
Hi Mehdi,
MPLS TE using RSVP-TE builds a topology including the SPF paths and non-SPF ones. Based on additional constraints such bandwidth, priority, affinity, etc,,, MPLS TE relies on Constraint-SPF to setup LSPs filling the ingress needs.
In your scenario RSVP-TE will setup a new LSP on the paths meeting the ingress traffic flows requirements regardless of the cost of the links in the tree.
I hope this helps
mcusine
Hi Mehdi,
Mauricio
Hi Mauricio,
When using dynamic path, thanks for your reply; let me try to rephrase my question pls:
If the best IGP path (R8-R9 on my diagram))has no more bandwidth left as per RSVP, when R2 wants to bring an LSP to R9 will this results in a creation of a new LSP (path over a sub-optimal path from an IGP point of view(like R2-R3-R4-R9) or will this result on an admission control failure and the new tunnel wont be up
Many thanks
Mehdi
Hi Mehdi,
King regards,
Hi Mehdi,
I hope this helps
