MPLS TE over Port-channel interfaces
slandreth
I get the following 'warning' when configuring MPLS TE on a port-channel interface. Any comments on what the limitations to using TE on a port-channel interface are?
7606(config)#interface port-channel99
7606(config-if)#mpls traffic-eng tunnels
%Warning: MPLS TE support is limited for port-channel interfaces.
For additional information, please contact the MPLS TE product manager.
5 Replies 5
smahbub
Level 6
Level 6
I think that you might be hitting the bug CSCsi55462.Traffic Engineering is not a supported configuration under
port-channel interface. However, limited support for Traffic
Engineering is allowed with the following caveats:
1) Zero bandwidth tunnel
2) No FRR support
I configured TE and FRR on Port-Channel also. I saw some TE Tunnels worked with FRR, some didn't. I enclose here for reference.
Router#sho mpls traffic-eng fast-reroute database
Headend frr information:
Protected tunnel In-label Out intf/label FRR intf/label Status
Tunnel1000 Tun hd Po1:implicit-nul Tu1004:implicit- ready
Tunnel1001 Tun hd Po2:implicit-nul Tu1005:implicit- ready
LSP midpoint frr information:
LSP identifier In-label Out intf/label FRR intf/label Status
Router#show mpls traffic-eng tunnels brief
Signalling Summary:
LSP Tunnels Process: running
Passive LSP Listener: running
RSVP Process: running
Forwarding: enabled
Periodic reoptimization: every 10 seconds, next in 8 seconds
Periodic FRR Promotion: every 300 seconds, next in 146 seconds
Periodic auto-bw collection: every 300 seconds, next in 133 seconds
TUNNEL NAME DESTINATION UP IF DOWN IF STATE/PROT
CISCO ISC-P139 172.16.254.253 - Po1 up/up
CISCO ISC-P141 172.16.254.252 - Po2 up/up
CISCO ISC-P145 172.16.254.251 - Po1 up/up
CISCO ISC-P147 172.16.254.250 - Po2 up/up
CISCO ISC-B181 172.16.254.253 - Po2 up/up
CISCO ISC-B182 172.16.254.252 - Po1 up/up
CISCO ISC-P166 172.16.254.254 Po2 - up/up
CISCO ISC-B187 172.16.254.252 Po1 Po2 up/up
CISCO ISC-B188 172.16.254.251 Po2 Po1 up/up
CISCO ISC-P159 172.16.254.254 Po1 - up/up
CISCO ISC-B185 172.16.254.250 Po1 Po2 up/up
CISCO ISC-B186 172.16.254.253 Po2 Po1 up/up
CISCO ISC-P173 172.16.254.254 Po2 - up/up
CISCO ISC-P174 172.16.254.253 Po2 Po1 up/up
CISCO ISC-B189 172.16.254.254 Po1 - up/up
CISCO ISC-B190 172.16.254.250 Po2 Po1 up/up
CISCO ISC-P153 172.16.254.252 Po1 Po2 up/up
CISCO ISC-P155 172.16.254.254 Po1 - up/up
CISCO ISC-B183 172.16.254.251 Po1 Po2 up/up
CISCO ISC-B184 172.16.254.254 Po2 - up/up
Displayed 6 (of 6) heads, 8 (of 8) midpoints, 6 (of 6) tails
Can you explain more detail about the limited support for TE on Port-channel?
Many thanks
Hi all,
I make some configuration mistake. It'w fixed and now all TE tunnel work with FRR.
By the way, can anyone explain more about the limited support for TE on port-channel?
Thanks anyway,
Hi, we have a similar problem. We aer trying configure MPLS TE under poertchannel interface, and it's not is not recognized. We have two chassis 6509 in VSS.
So, we need help.
Thanks.
