MPLS, vrf-select and PBR
sbrobak
Trying to configure some cs2821 with MPLS PE and vrf select based on PBR.
interface GigabitEthernet0/1.2
description ** Customer **
encapsulation dot1Q 2
ip vrf forwarding cust
ip address 10.10.2.1 255.255.255.252
ip policy route-map cust-pbr
route-map cust-pbr permit 10
match ip address custA
set vrf custA
route-map cust-pbr permit 20
match ip address custB
set vrf custB
It works, execpt that when I boot the router it removes the "set vrf " command.
I can't find any documentation except:
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpn_vrf_select_rt.html
Any ideas?
And, is PBR under vrf interface supported?
Reza Sharifi
Can you try "set ip vrf" instead or set ip next-hop and test again?
SUMMARY STEPS
1. enable
2. configure terminal
3. route-map map-tag [permit | deny] [sequence-number]
4. set ip vrf vrf-name next-hop {ip-address [... ip-address] | recursive ip-address}
or
set ip next-hop recursive vrf vrf-name ip-address [ip-address]
or
set ip global next-hop ip-address [ip-address]
5. match ip address {access-list-number [access-list-number... | access-list-name...] | access-list-name [access-list-number...| access-list-name] | prefix-list prefix-list-name [prefix-list-name...]}
or
match length minimum-length maximum-length
6. end
http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_mltvrf_slct_pbr.html#wp1053974
Thanks for the feedback, but these (as i understand) relates if your running vrf-lite (vrf forwarding on ingress and egress). Actually, found the following CSCdu70318. Looks like what I'm trying to do is not supported at this time.
