MPLS with a 1721
tb
Is it possible to install l3 MPLS VPN with a cisco 1721 and 1711 with the this IOSs c1700-adventerprisek9-mz.12.3-11.T2
c1700-entservicesk9-mz.12.3-11.T2, for Lab purpose?
cu thomas
jayjorda
Is your question in regard to using the 1721 or 1711 as the PE device for you L3 MPLS VPNs? I believe the lowest end platform you can use for the PE function is a 2691. You can check feature navigator to be sure however. The 1711 and 1721 can be used as CE devices however.
www.cisco.com/go/fn.
Hope this helps.
I know that the feature navigator tells this, but i also know that it is possible to install L3 MPLS VPNs with a 2610 as PE, with the right ios.
Another question, why i need a Feature like "EIGRP MPLS VPN PE-CE Site of Origin (SoO)" on a router which does not support MPLS.
cu thomas
