07-28-2017 04:38 PM
Hello Everyone,
Just trying to get an xconnect between two 3650 to work, but I can not ping between the customer sides.
I think the MPLS/LDP part is fine as it shows UP on both sides:
R#sh mpls l2t vc
Local intf Local circuit Dest address VC ID Status
Vl313 Eth VLAN 313 10.3.20.254 13 UP
and (the one PE):
R#ping mpls pseudowire 10.3.20.254 13
Sending 5, 72-byte MPLS Echos to 10.3.20.254,
timeout is 2 seconds, send interval is 0 msec:
Codes: '!' - success, '<...>
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/4/8 ms
Total Time Elapsed 31 ms
just in case here is the xconnect config:
R#sh run int gi 1/0/11
Building configuration...
Current configuration : 76 bytes
interface GigabitEthernet1/0/11
Description link to Customer
switchport mode trunk
no keepalive
end
R#sh run int vlan 313
Current configuration : 153 bytes
interface Vlan313
no ip address
xconnect 10.3.20.254 13 encapsulation mpls
remote circuit id 13
mtu 1500
remote link failure notification
end
and the Customer configuration:
interface GigabitEthernet0/0.313
encapsulation dot1Q 313
ip address 10.14.0.14 255.255.255.0
end
The configuration on both sides is symmetric and a ping from the Customer increases both physical interface counts, as does the vc statistic
(sorry the other PE)
N#sh mpls l2t vc 13 det
Local interface: Vl313 up, line protocol up, Eth VLAN 313 up
Interworking type is Ethernet
Destination address: 10.32.60.254, VC ID: 13, VC status: up
Output interface: Gi1/0/4, imposed label stack {20 26}
Preferred path: not configured
Default path: active
Next hop: 10.3.20.246
Create time: 00:56:18, last status change time: 00:56:18
Last label FSM state change time: 00:56:18
Signaling protocol: LDP, peer 10.32.60.254:0 up
Targeted Hello: 10.3.20.254(LDP Id) -> 10.32.60.254, LDP is UP
Graceful restart: not configured and not enabled
Non stop routing: not configured and not enabled
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last BFD dataplane status rcvd: Not sent
Last BFD peer monitor status rcvd: No fault
Last local AC circuit status rcvd: No fault
Last local AC circuit status sent: No fault
Last local PW i/f circ status rcvd: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 26, remote 26
Group ID: local n/a, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
Control Word: On (configured: autosense)
SSO Descriptor: 10.32.60.254/13, local label: 26
Dataplane:
SSM segment/switch IDs: 8217/4119 (used), PWID: 3
VC statistics:
transit packet totals: receive 0, send 10
transit byte totals: receive 0, send 900
transit packet drops: receive 0, seq error 0, send 0
Thanks for your time and help.
Mike
08-21-2017 06:39 PM
