MTU issue with L2 VFI + Bridge Domain - VPLS
ty.chan007
Hi all,
I am trying to test VPLS by using ASR1k as PE and cat6500 as P router. The diagram looks like below:
VLAN2 ---> CE-SW1 <--trunk--> PE01 <----> P01 <----> P02 <----> PE02 <--trunk--> CE-SW2 <-- VLAN3
Config is as below:
On both PE
l2 vfi VFI1 autodiscovery
vpn id 101
bridge-domain 200
mtu 9180
interface GigabitEthernet0/0/4
description CONNECT TO CE-SW
mtu 9216
no ip address
negotiation auto
service instance 202 ethernet
  encapsulation dot1q 2
  rewrite ingress tag pop 1 symmetric
  bridge-domain 200
The result on each PE are as below:
PE01#sh mpls l2transport vc 101 detail
Local interface: VFI VFI1 VFI up
  Interworking type is Ethernet
  Destination address: 111.90.180.0, VC ID: 101, VC status: up
    Output interface: Gi0/0/0, imposed label stack {22 269}
    Preferred path: not configured
    Default path: active
    Next hop: 111.90.180.85
  Create time: 01:08:44, last status change time: 01:03:38
  Signaling protocol: LDP, peer 111.90.180.0:0 up
    Targeted Hello: 111.90.180.2(LDP Id) -> 111.90.180.0, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last BFD dataplane     status rcvd: Not sent
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 266, remote 269
    PWID: 4156
    AGI: type 1, len 8, 000A 955B 0000 0065
    Local AII: type 1, len 4, 6F5A B402 (111.90.180.2)
    Remote AII: type 1, len 4, 6F5A B400 (111.90.180.0)
    VPLS-ID: 38235:101
    Group ID: local n/a, remote n/a
    MTU: local 9180, remote 9180
    Remote interface description:
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  SSO Descriptor: 111.90.180.0/101, local label: 266
    SSM segment/switch IDs: 4157/24629 (used), PWID: 4156
  VC statistics:
    transit packet totals: receive 6222138, send 2331620
    transit byte totals:   receive 9434194905, send 3554787086
    transit packet drops:  receive 35750, seq error 0, send 0
The problem that i am facing now is I can not send ethernet frame bigger then 1490bytes across the EVC/VPLS.
But if i try with EoMPLS config, we can send upto interface MTU which around 9000bytes.
Note: all core interfaces is MTU 9216 and IP MTU 1500.
What should go wrong? Please help.
CT
ty.chan007
anyone?
