hi
just need to ask if we have both ssm and asm range defined in a mpls multicast domain, which would be used to establishing the tunnel incase both ssm and asm ranges are similar. is there any preference to use ssm first and then ssm or vice-versa.
ip ssm range ssm-range
ip access-list standard ssm-range
10 permit 239.232.0.0 0.0.255.255
ip pim rp-address x.x.x.x asm-range
ip access-list standard asm-range
hope i made the question clear
